Washing Machines Logo
Question about Electrolux Washing Machines
How to fix my EWT854XW? the button in control panel only select preset,soak and wash the rinse and dry does not reach of the rotation when i pressed multiple times this button.?
Alisonjane
Posted by alison jane on
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
Posted on May 08, 2007
Healeyman
mike kirschbaum
  • 1198 Answers
SOURCE: rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
Posted on May 14, 2009
Anonymous
SOURCE: drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
Posted on May 17, 2009
proJekttaLon
Alan Timperley
  • 91 Answers
SOURCE: after the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
Posted on May 25, 2009
beltronic205
Gerry Harvey
  • 1482 Answers
SOURCE: We have a Hoover select 1500 washing machine. It
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Posted on Nov 11, 2009
Rinse solution on Fisher&Paykel dish washer not being used
Problem Possible Cause What to do Dishwasher will not start. No power. Ensure the dishwasher is plugged in and the power supply is turned on at the wall. The door is not properly closed. Close the door. Start/Pause button has not been pressed. Press the Start/Pause button . Water tap not turned on. Ensure water is connected and turned on. Blocked strainer in water inlet hose. Check the strainer and clean if necessary-it is located where the water inlet hose screws into the tap. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Lower spray arm rotates with difficulty. Spray arm holes are blocked by small items or food particles. Clean the spray arm. See 'Care and cleaning' for instructions. Cover of detergent dispenser cannot be closed. Detergent compartment has been overfilled. Remove detergent until the cover can be closed. Detergent dispenser is clogged with remnants of detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Remnants of detergent stuck inside dispenser. Compartment was damp when filled with detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Buttons beep and do not respond. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Water remains inside dishwasher after wash has ended. Drain hose is crimped, bent, or blocked. Check the drain hose and straighten if needed. Pump is jammed. Call your Fisher & Paykel Authorised Service Centre or Customer Care. Filter(s) blocked. Clean the filter(s). See 'Care and cleaning' for instructions. Foaming. Incorrect amount or type of detergent used. See section 'Adding detergent' or consult the detergent manufacturer's instructions. Too much egg in the wash load. Increase the amount of detergent. Rinse aid dosage level too high. Decrease the rinse aid dosage. Rinse aid spills not wiped up. Ensure that all rinse aid spills are wiped up when they occur. Water tap not turned on. Ensure water is connected and turned on. The dishwasher stops suddenly during the wash. Power or water supply has been interrupted. Check the power and water supplies. Knocking or rattling sound during wash. Spray arm knocking against dishes. Pause the wash and rearrange dishes. See sections 'CH and CHP models - Controls and starting a wash' or 'CK models - Controls and starting a wash', and 'Loading'. Dishes have been stacked incorrectly. Unclean dishes. Wash programme unsuitable for load. See section 'Wash programmes and detergent quantities' and select a suitable programme. Soils were too heavily baked on. Dishes may need soaking. Spray arm(s) unable to rotate. Ensure no items are obstructing the spray arm path. Dishwasher overloaded or incorrectly loaded. See the 'Loading' section. The filters are incorrectly inserted. See section 'Care and cleaning'. Detergent put in the wrong compartment. See sections 'Wash programmes and detergent quantities' and 'Adding detergent'. Excessive food not removed from dishes before loading. Scrape all food scraps off dishes before loading. Unsuitable detergent. Only use powdered or tablet detergent designed for domestic dishwashers. Not enough detergent. See 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load and the hardness of your water supply. Spray arm holes are blocked. Clean the spray arm(s). See 'Care and cleaning' for instructions. The filters are blocked. Clean the filters. See 'Care and cleaning' for instructions. Plastic items are discoloured (e.g. stain left by tomato sauce). Not enough detergent, not pre-rinsed. Pre-rinse plastic dishes before placing in the dishwasher and/or add more detergent. Alternatively, using the Rinse programme after adding dishes may minimise staining. Display flashing while Keylock is on. This is normal. The display remains on although the buttons are disabled. No action required. White stains are left on dishes; glasses have a milky appearance. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit the hardness of your water supply. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Dishes, cutlery have not dried. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Items removed too soon. After the end of the wash programme, leave the door ajar and wait for several minutes to help drying. Rinse aid dispenser empty. (The rinse aid indicators are lit.) Add rinse aid. See section 'Using rinse aid' for instructions. Glasses have dull appearance. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Tea stains or traces of lipstick have not been completely removed. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load. Wash temperature too low. Select a wash programme with a higher temperature (see section 'Wash programme data' for information). Traces of rust on cutlery. Cutlery is not sufficiently rustproof. Wash by hand. Glasses clouded and discoloured; milky coating Hard water situation. Increase detergent quantities. Glasses are not dishwasher proof. Wash by hand. Water marks left on glasses and cutlery. Rinse aid level or dosage setting is too low. Ensure there is rinse aid in dispenser. If necessary, increase the rinse aid setting or try using a wash programme with a higher temperature. See sections 'Using rinse aid' and 'Wash programme data'.
Nov 12, 2018 • Dishwashers
tip
How to Unlock Any Appliance or Turn Off Child Lock
<span style="font-weight: bold;">Bosch Dishwasher:</span><br /> <ol> <li>To deactivate, press and hold the "&lt;" button until the Child Lock LED goes out.</li></ol><span style="font-weight: bold;">Bosch Microwave:</span><br /> <ol> <li>Press "Settings" followed by the number "5" to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Bosch Washing Machine:</span><br /> <ol> <li>To deactivate Child Lock, press the Start/Pause button and hold down for 5 seconds.</li></ol>or<br /> <ol> <li>Press the Menu button until CHILD LOCK :ON appears in the display.</li> <li>Press the Select button until CHILD LOCK :OFF appears in the display.</li> <li>Press the Start/Pause button and the key symbol should disappear.<br /></li></ol><span style="font-weight: bold;">Danfoss Thermostat:</span><br /><br /> <ol> <li>Press the control knob or button and hold it in place.</li> <li>Turn the knob counterclockwise until you see the word "Code" appear in the display.</li> <li>Turn the knob clockwise and select the code "0033."</li> <li>Press on the control knob until you see an icon of a clock or a hand appear or disappear indicating that the child lock has been set or unset.</li></ol><span style="font-weight: bold;">Delonghi Microwave:</span><br /> <ol> <li>To deactivate Child Lock, press the STOP/CLEAR key until the beep is heard.</li></ol><span style="font-weight: bold;">Delonghi Portable Air Conditioner:</span><br /> <ol> <li>Pressing the "+" and "-" buttons on the control panel together for more than two seconds unlocks the keypad.</li></ol><span style="font-weight: bold;">Fisher & Paykel Dish Drawer:</span><br /> <ol> <li>Disable the child lock by pressing and holding the key with a key and lock symbol printed on it until the padlock symbol disappears from the screen.</li></ol><span style="font-weight: bold;">Frigidaire Dishwasher:</span><br /> <ol> <li>Press and hold the No Head Dry button (or the Rinse Only, Delay Start or Air Dry button depending on model) for 3 seconds.</li></ol><span style="font-weight: bold;">Frigidaire Dryer:</span><br /> <ol> <li>Press and hold the "Control Lock" button for five seconds to release the lock.</li></ol>or<br /> <ol> <li>Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.</li></ol><span style="font-weight: bold;">GE Dishwasher:</span><br /> <ol> <li>Press and hold the Heated Dry button for 3 secs.</li></ol><span style="font-weight: bold;">GE Electric Stove:</span><br /> <ol> <li>Press and hold "Lock" for three seconds to release the child lock function.</li></ol><span style="font-weight: bold;">Kenmore Dishwashers:</span><br /> <ol> <li>Press the "Heated Dry" button, and hold for four seconds until the "Lock On" icon light turns off.</li></ol>or<br /> <ol> <li>Hold the "Sensor Dry" or "Lock" symbol down for three seconds until the lock indicator light goes off.</li></ol><span style="font-weight: bold;">Kenmore Dryer:</span><br /> <ol> <li>Press and hold the AUTO DRY LEVEL button for 3 seconds.</li></ol><span style="font-weight: bold;">Kenmore Microwave:</span><br /> <ol> <li>Touch and hold Cancel for 5 seconds to deactivate the lock.</li></ol><span style="font-weight: bold;">Kenmore Range:</span><br /> <ol> <li>Push and hold the Lock button for 10 seconds.</li></ol><span style="font-weight: bold;">Kenmore Washing Machine:</span><br /> <ol> <li>Press and hold "Drain & Spin" for 3 seconds to release the child lock.</li></ol>or<br /> <ol> <li>Press and hold Cancel for 10 seconds.</li></ol>or<br /> <ol> <li>Hold the "End of Cycle" button down for 5 to 6 seconds.</li></ol>or<br /> <ol> <li>Hold the Child Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Dishwasher:</span><br /> <ol> <li>Press and hold Energy Saver/Dry button for 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Microwave:</span><br /> <ol> <li>Press and hold the "Cancel" or "Start" button for five seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Oven:</span><br /> <ol> <li>Touch and hold START for 5 seconds.</li></ol><span style="font-weight: bold;">LG Dishwasher:</span><br /> <ol> <li>Press and hold the Spray and Rinse button simultaneously for 3 seconds.</li></ol><span style="font-weight: bold;">LG Dryer:</span><br /> <ol> <li>In models that include a rack dry, usually holding the [rack dry] button for three seconds will disable the function.</li></ol><span style="font-weight: bold;">LG Refrigerator:</span><br /> <ol> <li>Press and hold the Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">LG TV:</span><br /> <ol> <li>Open the menu, select lock (padlock symbol) then select lock system, then select off.</li> <li>Press exit to exit the menu.<br /></li></ol><span style="font-weight: bold;">LG Washing Machine:</span><br /> <ol> <li>Press and hold "Dry" & "Spin" buttons together for a few seconds. </li></ol>or<br /> <ol> <li>Press and hold "options & select" until the light goes off.</li></ol>or<br /> <ol> <li>Press and hold "end of cycle" for over 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold the PRE-WASH/Child Lock buttons for 3 seconds. </li></ol><span style="font-weight: bold;">Maytag Dishwasher:</span><br /> <ol> <li>Press the Heated Dry button for three seconds.</li></ol><span style="font-weight: bold;">Maytag Microwave:</span><br /> <ol> <li>Press and hold the "Enter/Start" button for 3 seconds</li></ol><span style="font-weight: bold;">Panasonic Microwave:</span><br /> <ol> <li>Press "Stop/Cancel" 3 times to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Philips TV:</span><br /> <ol> <li>Using your TV Remote, press the 'MENU' button, select FEATURES and press cursor right.</li> <li>Press cursor up/down to select CHILD LOCK and press cursor right.</li> <li>The screen will prompt you for PASSWORD, key in you password if known. If the password is unknown, then key in the code 0711 twice.</li> <li>Press cursor up/down to select CHILD LOCK, press cursor right to change the status to OFF.<br /></li></ol><span style="font-weight: bold;">Samsung Dishwasher:</span><br /> <ol> <li>Hold down the Delicate and Rinse buttons simultaneously for three 3 seconds.<br /></li></ol><span style="font-weight: bold;">Samsung Refrigerator:</span><br /> <ol> <li>Press and hold the Ice Off/Lock button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Ice Off button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Lighting button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Child Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Dishwasher:</span><br /> <ol> <li>Press and hold Heated Dry button for 4 secs.</li></ol><span style="font-weight: bold;">Whirlpool Dryer:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Washing Machine:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol>
on Jun 17, 2011 • Washing Machines
Dishes are soaking wet at end of cycle. Is this normal?
No, it's not normal for them to be soaking wet at the end of the cycle, but there are things that can affect this. First, make sure you have Heated Dry selected. Next, make sure you are using rinse-aid (Jet Dry), because the new dishwashers don't use as much heat as the older dishwashers, and Jet Dry will greatly aid in the drying. Be aware that plastics won't get dry in any dishwasher. Other things you can do is turn on the extra heat options in the wash cycle, and turn on the Sani-Rinse option (if you DW has such options). Otherwise, you may have a heater or controller problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
How do i reset the consol on a westinghouse dishwasher with the buttons rinse only, quick wash, china crystal, normal, pots and pans, soak and scour, hi temp scour, sani scour, air dry and cancel?
Normally you will have to press High Temp and Air dry button alternatively 3 to 4 times within 8 secs until the whole panel lights up. Then press Cancel. That should reset the dishwasher.
Hope this helps. Welcome to fixya.com.. It is a public forum and you can also answer questions by selecting Solve Problems and answering solutions for problems on categories that you are comfortable with.
Sony how to change the bass on my sony mex bt3100u stereo
Hello Tom,
You may have to adjust the EQ7 Preset to XPLOD and then listen to the jam. Here are the instructions from the bt3100u manual:
Selecting the sound quality
- EQ7 Preset
You can select an equalizer curve from 7 equalizer curves ("XPLOD," "VOCAL," "EDGE," "CRUISE," "SPACE," "GRAVITY," "CUSTOM" or "OFF").
1 During reception/playback, press the select button.
2 Rotate the control dial until "EQ7 PRESET" appears, then press it.
3 Rotate the control dial until the desired equalizer curve appears, then press it.
4 Press (BACK).
The display returns to normal reception/play mode. To cancel the equalizer curve, repeat the first 2 steps then select "OFF" in step 3.
Tip
The equalizer curve setting can be memorized for each source.
We hope that this helps. If not please return and post how this went.
How to put a laguna radoi code in
PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don`t have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digit to be displayed Press the Third Preset Button repeatedly for 3rd digit to be displayed Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code ) ============================================================
2helpful
Im trying to find out how to enter the radio code for a factory fitted stereo. A family member has just been given a renault 19 1994/1995. We have the code but, no user manual for stereo. Any help would...
4helpful
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
6helpful
2answers
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
I have a new ESTR 200 that has been in a closet for a couple of years. Very little seems to function well. The presets will not hold if I turn the system off or if I turn to another function. Record...
I assume we're talking about the Element ESTR200...
A turntable will not work with this receiver unless the TT is already preamplified. No Phono Preamp in this unit.
Presets:
From the manual...
Store a station
1. Press the FM/AM button on the front panel (or
the AM/FM button on the remote).
2. Select the station you want to store in memory
by the methods described above.
3. Press the MEMORY button on the remote
While "MEMORY" is glittering, press number
buttons on the remote for the station.
If the Memory indicator on the display turns off before you preset the station selection, Press Memory again.
Manual preset
1. Select the band wave by pressing FM/AM
repeat.
2. Turn to a radio station(see "Manual tuning" on
page 8 in details).
3. Select a group (A- D) of preset stations. This
group will be displayed on the front panel.
For example: "A".
4. Press MEMORY on the remote control.
"MEMORY"will appear on the display.
5. While the word "MEM" appears, input your desired preset number (1-8 ) by using the numeric keys on the remote control to store the radio station. For example this number is "1", the station is stored as "A1".
NOTE:
A new setting can cover the former one.
This memory is kept before next reset.
Retrieving preset stations
1. Press FM/AM button on the front panel or the
remote control to select tuner mode.
2. Press A/B/C/D button on the front panel or the
remote control to select the group of preset stations that you require.
3. Press the numeric keys on the remote control to select the number of preset station that you require. Station selected is displayed on the front panel.
4. By the same way, you can select other stored
stations.
The remote control does not operate the unit.
-Another function is selected on the remote.
Press the correct function button.
-No batteries installed. Install the batteries before
using the remote.
Be sure "+" and "-" marks of each battery match the symbol on the inside of the remote battery compartment.
-The batteries are exhausted. Replace all batteries.
-The remote is not pointed at the remote control sensor on the main unit or there is an obstacle between the remote and the main unit.
-The remote control is too far away from the main
unit, move closer.
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
