Question about Dictaphone Audio Players & Recorders
Dictaphone 1243 is stuck in Record mode; any ideas how it can be freed?
Posted by john43855 on
1 Related Answer
3vil3lvis
  • 43 Answers
SOURCE: Eject the tape from a Dictaphone 1243 voice recorder
The top cover slides down, and then the cassette should easily lift out.
Posted on Mar 16, 2009
Best dictaphone for conference Recording
Hello the Dictaphone 2740 does not have the option for telephone record or conference recording you need the Model that is really similar to the 2740 the model is 2750 this model has telephone record option and conference record capable.
Note: for telephone record you need to buy a separate adaptor like this ECS-DPRC
Aug 12, 2011 | Dictaphone 2740 Desktop Cassette...
The small spring clip in the bottom that holds pressure on the tape has popped out. How do I get at it to slip it back in.
Hello I stronglly suggest to send your unit to service
Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Oct 27, 2010 | Dictaphone 1243 Handheld Cassette Voice...
Dictaphone use for Medical Transcription
You'll need a digital recorder (Dictaphone makes one - a Walkabout Model 5220). Transferring a recording from an analog (tape) machine to a PC requires a patch cord to hook it up to your PC, then some sort of software to record it while it's playing back.
May 12, 2010 | Dictaphone 1243 Handheld Cassette Voice...
How to transfer voicemail onto cassette tape using Dictaphone 2750
Hello you will need and phone recor adaptor I recomend to used http://www.tvps.com/Products/1ECS-DUPR-Telephone-Record-Adapter---New__ECS-DUPR.aspx when your are ready just press and hold for 2 seconds telephone record button on your Dictaphone 2750 when your listen to your voicemail.
Apr 05, 2010 | Dictaphone 2750 Desktop Cassette...
Dictaphone 1243
I'd try cleaning the internal switches on the main PCB. You'll have to remove the back cover on the portable (3 screws) and the remove the four screws on the PCB and CAREFULLY flip the PCB over to reveal the switches.
I assume the portable plays fine, but just won't rewind?
Apr 10, 2009 | Dictaphone 1243 Handheld Cassette Voice...
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Mar 15, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Instructions for speaking into a hand held dictaphone
Make sure that 'VOX' or 'VA' isn't turned on. This is Voice Activated recording and is designed to record only when the person is talking. The problem is that sometimes it'll cut in or out when you don't want it to.
Also, if the handheld has a 'Dict/Conf' switch, put it into 'Dict'. The 'Conf' setting is for conference recording - which will make the mic more sensitive and pick up more background noise.
Feb 13, 2008 | Dictaphone 1243 Handheld Cassette Voice...
138 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
