Question about Disney Televison & Video
Need to switch Disney Princess Television from Cable to Antennae
Reprogram Princess TV from Cable mode to Antennae Mode
Posted by Thomas Brickers on
4 Related Answers
Anonymous
SOURCE: Service mode Tv Disney
I need code for entered service mode Tv Disney 14DN1WYD-PRINCESS
Thanks
Posted on May 26, 2008
Anonymous
SOURCE: disney princess 13" tb p1300 ntv
disney will replace for around 30 dollars. Google disney customer service and get number is you are interested.
Posted on Aug 22, 2008
Anonymous
  • 9 Answers
SOURCE: Disney 13' Princess tv
You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Hope this helps
Posted on Jan 16, 2009
CaptainHawk1
Shawn O'Halloran
  • 345 Answers
SOURCE: How do I get to
Sorry to be the bearer of bad news on this but you don't have the remote for this TV, you're out of luck. This is one of the many problems with this TV. The other is that there is not a universal remote control in existence that has codes or signals programmed into it to operate it. I know all this because I've gone through the exact same issues with it as my daughter has this TV. So unfortunately, you're stuck.
Posted on May 28, 2011
How do i get vcr to work with tv
The connection would be ideally a SCART cable or a phono AV cable ( red, white, yellow) which are you using? Then turn on TV, then turn on VHS, if the VHS does not show on screen, press the AV/Mode button on remote until VHS on screen!
Dec 15, 2014 | Disney Princess TV/DVD Combo
Our tv remote for the Disney princess tv doesn't work. So how do we get to input so we can watch Dvds on the princess dvd player? The dvd player remote works. It's the tv remote that doesn't. And if I...
Hi:
Frist use your cell phone camera mode to see if remote is putting out IR signal, you should be able to see the Infared led light up on the cell phone display, if it does then remote is good and IR receiver inside the Tv is at fault. Just point the remote at you cell phone camera while pushing a button on the remote.
Apr 17, 2011 | Disney Princess 13'' TV Recorder
I have a Disney Princess 13" color television, and I cannot get cable channels to work. I read the insturction manual, but get confussed at "ATV AIR" or ATV CATV" or "DTV AIR" or "DTV CATV"..I did hit...
Need more details. Is it an hdmi hookup or a coaxial? Is your cable line hooked up directly to the TV or are you using a modem? Is it a smart TV or just regular?
Jun 13, 2017 | Disney Princess TV/DVD Combo
Dvd player won't play on the television
have you switched the tv to the av channel because a scart lead goes to the av channel shown on a remote as a box with an arrow pointing out or a av button hope this helps.
Jun 03, 2009 | Novelty Telemania 026148 Brand Disney...
I have a disney princess tv and just got a disney princess dvd player and I cant get the dvd player to play dvds
when we first got ours i put a dvd in and it wouldnt play either then i noticed you have to push the input buttons until it is on dvd mode every time you play a dvd
Dec 29, 2008 | Disney Princess DVD Player
Disney princess 13" tb p1300 ntv
Apr 07, 2008 | Disney 13" TV
Swiching from tv to playing video
sorry. you cannot switch to video mode without the remotes
Feb 21, 2008 | Disney Princess MCP DVD2050P DVD Player
Thanks
Nov 30, 2007 | Disney DT1350-P 13" TV
Televison & Video Logo
44 people viewed this question
Top Disney Televison & Video Experts
Lee Hodgson
Lee Hodgson
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
