Question about Video Cameras
Good morning!! I think my pictures are storing on the camera instead of the card. How do I switch that, & how do i erase pics from camera?
This is for a moultrie deer trail camera
Posted by Shorty Coblentz on
5 Related Answers
Anonymous
SOURCE: reset picture number and erase pictures on moultrie game camera
Go to images.ebsco.com/pob/moultrie/catalog/dgs-200 instructions
This is the complete manual for the camera game spy 200.
Posted on Jan 28, 2009
Anonymous
SOURCE: moultrie game camera won't flash
we get beutiful day pics, but totally black pics at night
Posted on Aug 23, 2009
Steve
  • 3289 Answers
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Posted on Oct 20, 2009
Ronald Lockhart
  • 296 Answers
SOURCE: user manual needed for a moultrie mfd-cdc model
here's your manual:
http://images.ebsco.com/pob/Moultrie/catalog/GameSpy100V2Manual.pdf
Posted on Feb 20, 2010
cena2fight
  • 3 Answers
SOURCE: Bushnell Trail camera won't store pictures
my trail camerawant take pictures
Posted on Jun 10, 2010
How do I erase pics on a digital frame model DS13009?
take out the SD card put it in either your pc or camera & erase the pictures from there then add any other pictures from your pc & replace the card
Nov 11, 2014 | Cameras
After downloading pictures with the "erase after downloading" box checked it starts to erase the pictures as expected, but hangs at pic 37. Is the memory card faulty, or is it a software bug?
I'm not sure what's causing that problem, but it will be much faster each time you download photos to not erase after downloading. Instead, find the option on your camera to format the card, and it will erase everything on the card in one process. It's much faster.
Mar 06, 2011 | Nikon Coolpix S3000 Digital Camera
I've forgotten how to erase the whole memory card. I can do individual pics but that would take forever.
Format the card to erase it completely. Formatting should be done each time you finish download all your pictures from it, instead of deleting individual pictures.
Jan 05, 2011 | Olympus Camedia D-360L Digital Camera
How do I erase all the pictures from a Nikon memory card? I'd like to wipe the memory card clean while it is in the printer slot.
That's not a good idea. If you have stored the pics safely on your computer, you can completely erase the card in the camera by going into the menu and finding "format"...follow the on-screen instructions.
Jun 06, 2010 | Nikon Coolpix 2100 Digital Camera
I have a cannon 580 i lost all the photos but i did not erase them could they be stored somewhere else on the camera
Get a card reader and try to download your pics. Or, take your card to a store like Walmart that has a Kodak Picture Kiosk and insert your card. You can print your pics or make a cd of them
Jan 31, 2010 | Cameras
My camera won't take pics
Did you erase the card using the computer instead of the camera? If so, that's your problem. The camera still sees all the pictures and thinks the card is full. You should format the card in the camera to completely erase it.
Jan 26, 2010 | Cameras
My camera erased my pictures
These cameras have an internal store and also can use a card. So, when you add a card, it is writing to that store and only shows you the pictures stored there unless you change the device settings or remove the card.
If so, the images you have on the EasyShare One internal store may be originals
Another possibility is that you did a BragBook synch to EasyShare and you might be able to see these images in your 'Favorites' view. The 'Camera Favorites' or BragBook pictures are a smaller version of original images, to allow you to carry more pictures with you to share, but these pictures may be a lower resolution version of the images you took. They would be sufficient for printing 4x6 pictures, but not enlargements.
Change to Favorites mode to see if they show up that way.
DigiChick.
May 21, 2008 | Kodak EasyShare One Digital Camera
Erasing pictures
If you erase them off your memory card they shouldn't be transfering back onto your computer. I would say that maybe they are saved on your internal memory of the camera also. Take your memory card out and see if when you turn the camera on you have pics in the camera stored. If you do delete them then. :)
Jan 04, 2008 | Casio Exilim EX-V7 Digital Camera
Saved pics
Hi,if dont have any very important picture stored in camera you may reformat it all protect picture will erase , the camera sim has no more vacant its full you connot store picture anymore best solution is to reformat it.press menu , press setup,navigate down select format. then okey.
Dec 11, 2007 | Cobra Digital DC6550 Digital Camera
Video Cameras Logo
82 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
