Question about Video Cameras
How do i transfer all stored images on my Browning trail camera to an SD card
Posted by Mike Reid on
5 Related Answers
Anonymous
SOURCE: transferring stored data from micro SD card on G1 to new one
plug your G1 to your PC via a USB cable that came with it .., once you plug it in you'll get a notification entitled USB connected .. select it and then choose mount ... once thats done open your My computer icon , you'll see an exrta drive that wasn't there be4 somethig like K or M .. open that and you'll see all the content of your SD card .. copy and past everything to a folder anywhere in your computer ... then all you gotta do is replace the SD card , repeat the same proccess but then time copy everything back to your new SD card .
Posted on Feb 02, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: how to transfer internal images to sd card?
Put memory card in camera, power up, go to menu and find copy option, select it and press ok.
That will copy picture files from internal memory to memory card.
Posted on Jun 17, 2009
dvdcdlaser
Dvdcdlaser
  • 1285 Answers
SOURCE: Cannot transfer photo from my SD card to computer
either your pc card reader or adapter for sd card is at fault here....but try this way connect your camera to pc (using usb cable)...go to my computer see the new device (camera) click on it to open ...your pix are there now copy & paste (click & drag) to your folder on the pc...hope this is helpful...feel free to rate
Posted on Jul 08, 2009
Steve
  • 3289 Answers
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Posted on Oct 20, 2009
cena2fight
  • 3 Answers
SOURCE: Bushnell Trail camera won't store pictures
my trail camerawant take pictures
Posted on Jun 10, 2010
My Browning trail camera did not transfer images to the SD card. How do I view what's stored on the camera? Thanks
Normally, images are ONLY stored on the SD card, so if you have nothing on it, then you have no images. Either the card is faulty, the camera is faulty, the card wasn't formatted, or was the wrong card type.
All the manuals are here.
Browning Trail Cameras
Nov 27, 2016 | Cameras
How can I set this camera up to overwrite the images on the SD card?
For many of these types of Trail Cams, you cannot instruct it to overwrite images, you just need to reformat the SD card using the camera's menu option for that function.
May 15, 2014 | Simmons 119422C ProHunter Trail Cam 6mp...
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Feb 22, 2010 | Pentax Optio S5z Digital Camera
Lumix® digital camera storage path
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
Aug 31, 2005 | Panasonic Lumix DMC-LC5 Digital Camera
Aug 31, 2005 | Panasonic Lumix DMC-LC43 Digital Camera
Aug 31, 2005 | Panasonic Lumix DMC-LC40 Digital Camera
Aug 31, 2005 | Panasonic Lumix DMC-LC33 Digital Camera
Aug 31, 2005 | Panasonic Lumix DMC-LC20 Digital Camera
Aug 31, 2005 | Panasonic Lumix DMC-LC1 Digital Camera
Aug 31, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Video Cameras Logo
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
