I don't have the remote control for that tv
SOURCE: Echostar IR remote (Dish)
to set remote to tv
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
SOURCE: Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
SOURCE: comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
SOURCE: I m trying to program my RC64 remote for Direct TV
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Testimonial: "Thank you thank you thank you!!!!!"
