The only thing I have done is to channge the wallpaper on each of them.The names were showing before I changed k t but not now.
SOURCE: Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
SOURCE: Page numbers in PDF
Change the number in the pages tab. right click any page and select number pages
SOURCE: wallpaper and screensaver settings on desktop
Hi are you connecting the laptop to a lan , If yes it will happen because admin guys will have deployed from server.
SOURCE: Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
SOURCE: My Computer Keeps Loging Me Off,It Shows My
If you are using Windows XP, see if you can go to the system restore :
START --> Programs or All Programs --> Accessories --> System Tools --> and when ever you noticed this problem started... see if you can revert back to the date just before this problem started to occur.
do not worry - all your files should remain there even though you revert back to a time that is earlier. The only thing is that anything from that point till today's current date that you have installed would be lost.
