Question about Cycling
I have 26" Avalon purple women's bike I would like to replace tires w wider more heavy duty tire. Is this possible ??
Posted by Rhonda King on
Donald Ayers-Marsh
  • Cycling Master
  • 1,389 Answers
If the current tire is not 26 x 1 3/8 you can probably put on a wider tire, but don't go overboard, and be sure it will clear the frame on the sides. For example, if you have 26 x 1.75 then 26 x 2.0 would be fine, 26 x 2.25 may be too much.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Posted on Nov 25, 2016
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: I have an Oglaend DBS Sport bike that needs new
DansComp.com Has BMx Parts And
http://www.bikeparts.com/ Has Moutian bike parts 26 x 1 3/8 might fit
Posted on Jul 24, 2009
Polymath5000
Jerry
  • 35 Answers
SOURCE: Is there any problem with mounting a 24x1.75 tire
Strictly speaking:
Typically, 24x1.375 (1-3/8") wheels are either 540mm ("E5") or 547mm ("S5") in diameter. (Yes, annoying as it is, 24 inches doesn't always mean 24 inches!)
If you're planning on fitting a 24x1.75 tire, make sure it is the proper diameter to fit the rim. Since the wheel was from a Huffy, it's probably an S5, or 547mm rim.
Practically speaking:
Any 24x1.75 tire will probably fit the rim. As long as the tire's bead seats on the rim, the 3/8" difference in width should not present any problems.
more info on tire/wheel sizing:
http://www.sheldonbrown.com/tire_sizing.html
Posted on Oct 28, 2009
Testimonial: "Thanks for the info! I did not know that there are different diameters for 24" tires. Now that I know what to look for, I can make good decisions."
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: i'm trying to date my Schwinn bike. Serial # is
looks like a 1950 model
Check it out for your self on the link below by clicking it on
http://www.re-cycle.com/History/Schwinn/SwnB_Serial.aspx
Posted on Jul 08, 2010
Anonymous
  • 57 Answers
SOURCE: How do you fill the
There are two types of valve stems, schrader ( like the valve stems on your car ) and presta. See images on this page http://www.sheldonbrown.com/brandt/presta-schrader.html Since you are asking I assume you have presta valves. You can get an adapter to convert the presta valves for use with a schrader pump. Unscrew the small knurled nut on top of the presta valve to open it, press down and release the small top to ensure the valve is free to move. Snug up the top when it is full.
Posted on Dec 23, 2010
sexymamalea
Lea Deptula
  • 3 Answers
SOURCE: why did my tire warp
Buy a better bike!
Posted on Jul 22, 2012
2001 Vulcan 1500 Classic E. Can I put a wider back tire on and if I can how wide can I go?
talk this over with a bike shop that sells rims and tires
there are several things to consider
ride characteristics change dramatically with different tire widths
legal ramifications of different front and rear tires
real advantages of wider tires as against "looks cool"
costs of new rim and wider tire against standard tires
modification plates for the wider tire
Talk it over with an accredited bike shop and find a person that has real experience and not just a salesman
Mar 08, 2016 | kawasaki Motorcycles
I have a Schwinn women's 21 speed Frontier. Frame in purple serial #0378. I wanted to know the year and specs. On it? Thank you!
First thing, is headbadge black and red? Does it say it was made in China, either on the headbadge or somewhere else on the frame. If so, the bike has no value as an antique bicycle. If its in running condition, tires hold air, brakes work and gears shift its about a $60 to $ 75 bike
Sep 22, 2014 | Schwinn Frontier 21 Speed Mountain Bike...
How to change rear tire schwinn suburban womens bike
Remove wheel, take it to the nearest bike shop for correct replacement and tire sizing. Schwinn tires are different than other tires. They use fractions rather than the decimal system everybody else uses. So a Schwinn tire won't fit on a decimal rim and a decimal tire won't fit on a Schwinn rim
Jun 01, 2014 | Schwinn Cycling
Troubleshooting guide
Are tires fully inflated? Is there any thing in the chain or around the chain? Suggest taking it to local bike shop
Apr 23, 2014 | Schwinn Windwood 26 Women s Cruiser...
16 inch bicycle tire is flat. Need replacement, where to buy?
Call Dynacraft (bike maker) at 1-800-551-0032. My daughter's rear tire was flat and they sent out a new tube for free. She had the bike for only about 4 months. They also sent out a new rear tire as bearing/coaster brake assembly was make noises. The only problem is her original rim was purple and they sent out a silver colored rim as they don't have purple replacement part. I also had to install the tube and tire on the new rim. They only send replacement parts not assemblies.
Sep 16, 2010 | Dynacraft Girls 16" Barbie Bike
Chain slipping after changing tire
You may have knocked the gear derailleur when fixing and re-fitting the rear wheel. This can knock the derailleur out of whack slightly and will need proper adjusting by your local bike shop.
Jun 02, 2010 | Schwinn Windwood 26 Women s Cruiser...
I am having trouble putting the front tire on my Schwinn Merge 26'' Women's Mountain Bicycle
The easiest way to put on or take off a tire is to release the break cable. Bikes nowadays have a quick release for the break cables and that will release the pressure on the break pads.
May 21, 2010 | Cycling
Denali GMC 700C Women's road bike wrong tires!!!
Can you explain why you think the tires are too big? Do they NOT fit the rims? What condition was this bike in when you bought it? If the brake pads line up with the rims then the wheels are correctly sized for the frame.
May 06, 2010 | GMC Denali 700cc Women's Road Bicycle
Feeling a vibration in the bike only in gear at the 3-3.5k rpm range that the only way i can think to explaing is a feeling of a sticky bearning. does not do it in neutral
It could be wheel/tire balancing issue if you only feel the vibration at highway speeds (60 mph and above) then higher speeds it goes away.
I've worked with tires and rims on trucks, bikes and cars and have found that a harmonic vibration is usually caused by tires being out of balance.
Perhaps the dealer could check for a vibration on a dyno.
For the DIY bikers.....Use CAUTION but, the Old school routine would be to raise the wheels (heavy duty Bike Jack) strap it down and spin the tires by hand and check the rims for run out (to the sides) and the tires to see if they are round and true.
Then spin the rear tires to speed (3500rpm) to see if the shaking/vibration is there. Also rotate/spin the front tire and see if there is a heavy spot that will settle to the bottom. Add a the appropriate weight (1/4 oz stick on weight) to the opposite side (180 degrees) of the heavy spot. Spin again and see if totally random spots settle to the bottom. Road test and see if it improves.
Oct 05, 2009 | 2008 Harley Davidson FLHX Street Glide
Cycling Logo
189 people viewed this question
Top Cycling Experts
Marvin
Marvin
John Egan
John Egan
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
