Question about In Microwave Ovens
SOURCE: Microwave Oven Does Not Start Cooking
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Posted on Dec 25, 2008
SOURCE: I can't cancel the auto cook
Posted on Apr 01, 2009
SOURCE: oven won't function after 5 minutes of cook time with nothing in
It's posible that since it was running empty, the magnetron overheated
and a thermal cutout or thermostat located on the magnetron opened.
Magnetrons may be protected by a thermostat, which will reset when it cools, or a
thermal fuse, which is a one-time use device. It is also possible that
in some cases, a thermostat will fail when opened.
In the worst case the magnetron may be damaged due to running empty.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Posted on Apr 07, 2009
SOURCE: Hi I have an Emerson microwave oven MW8998B. The
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
Posted on May 15, 2009
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
Posted on May 30, 2009
Feb 06, 2015 | In Microwave Ovens
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Nov 21, 2010 | Microwave Ovens
Aug 09, 2010 | General Electric Microwave Oven
Dec 25, 2009 | GE Advantium 120 Convection/Microwave Oven
Apr 06, 2009 | Microwave Ovens
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
Jul 25, 2008 | Microwave Ovens
Jul 02, 2008 | Sanyo Microwave Ovens
Oct 18, 2019 | In Microwave Ovens
Sep 11, 2019 | In Microwave Ovens
205 people viewed this question
