Question about Proton Televison & Video
The screen is green when I turned on my Proton 4250 42 In. LCD Television
Posted by Juan Rodas on
Electro Med Services
  • Proton Master
  • 6,694 Answers
The TCON board or the LCD panel is faulty. You have to change the tcon board to confirm the fault
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Nov 24, 2016
1 Related Answer
freetek
Steve Allison
  • 5569 Answers
SOURCE: the red light for power
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, the PSU may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the mfr. and install it yourself but it will likely have the same problem eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload and the power supply for the backlight may have failed and is causing an overload shutting down the main supply.
Posted on Mar 24, 2011
Sound works < but no picture
Proton LCD TV, Hi, most LCD's and Plasma's have a cold/ hot circuit and the board for video and audio are the same usually it's a main board but before going through all that check to be sure that it's not a setting or volume adjustment. older model proton TV's exchange the main board these usually go bad IU would search any auction sites for a similar model with a broken screen and take out the needed parts for this fix, otherwise your better of getting a more updated LCD TV good thing is that they are way cheaper now
Feb 26, 2014 | Protron PLTV-32 Television
How can I adjust the picture colors?
There are several performance issues you may encounter with your Protron PLTV-37C LCD television.
Some problems include the television not turning on, issues with the TV's picture and issues with the TV's sound.
Depending on the type of problem you encounter, there are several options available to you to solve it.
Power Issues
Check the TV's main power cord. If it is not plugged in or is loose, securely plug it in to an electrical socket.
Unplug the television and plug it in to another electrical socket.
If the one it is plugged in to currently is bad, the television does not receive power.
Try turning the television on with the remote.
If that does not work, try turning the television on with the power button on the TV's front panel.
If that works, then remove the battery cover from the remote.
Remove the current batteries and replace them with fresh batteries.
Picture Issues
Check the video cables.
If they are loose or disconnected, securely connect them.
Adjust the television's brightness.
If the brightness is set too dark, images on the screen are extremely difficult to see.
Check the power indicator on the front panel of the television.
If it is red, the television is in power-saving mode.
Simply press any button on the remote to bring the television out of power-saving mode.
Audio Issues
Check the audio cables. If they are loose or disconnected, securely reconnect them.
Turn to different channels and adjust the volume.
It is possible that some channels are coming in quieter than others.
Access the audio options from the main menu. Check what audio setting the TV is at.
If it is set to "Mono," change it to "Stereo."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dde1880d298054849d8c8adc90514f40&modelid=22971545&q=Proton+CS-37
Specifications for Proton CS-37 / PS-47
Aug 09, 2013 | Protron PLTV-37 37 in. LCD Television
My proton LCD 32'' has sound but no pictures.
If you need a board write the board number down. Try LCDparts.net and see if you can match board with what they have.
Apr 26, 2010 | Protron PLTV-32 Television
Shadows on lcd
Why does my lcd proton Television have a long black streak on the right side of the screen?
Sep 25, 2009 | Televison & Video
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
Lost power cord
Proton Introduces Elegant 37-Inch Puriti™ High-Definition LCD TV ... Each Protontelevision combines forward-thinking industrial design with the most ...
www.proton-usa.com
Nov 17, 2007 | Protron PLTV-37 37 in. LCD Television
Televison & Video Logo
27 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
ray gallant
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
