Question about LG Washing Machines
My LG Fuzzy Logic Turbo Drum 13 Kg Top Loader don't stop taking water at any level and then it overflows. What can be the problem or how can I sort this issue out
Posted by Lenie on
paul
  • 825 Answers
There is a pressure valve inside.........look around the drum with lid off.......look for thin pipe from bottom of drum to small unit.........that is the valve switch.........remove pipe blow and suck on the valve switch listern for a click.........no click.......replace the valve switch........
cheers
Posted on Dec 11, 2016
3 Related Answers
Dissolu
Gintautas Maldzius
  • 221 Answers
SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Posted on Aug 07, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
Lee Pinski
  • 18 Answers
SOURCE: i have a lg fuzzy logic 7.5 kg WF-T755A washing machine that has stopped spinning and also stopped agitating in washing cycle
Call LG's support line, they have excellent customer service.
Posted on Apr 04, 2013
Lg fuzzy logic 7.kg turbo drum top loader model wf-t7051td does not agitate or spin properly
I would call the washing machine engineer for a quote as there are to many things that can go wrong eric
I have lg fuzzy logic turbo drum 7 kg T6515TDPT01 water input is continous its not stopping
Check the water inlet valve for condition, replace if faulty.
The main control board could also be at fault, but it is not common.
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
My 8.5 kg top loader fuzzy logic turbo drum keeps leaking and also has started to refill about a 1/4 of the drum when it finishes a cycle what is the problem
the problem could be that the water sensor is not giving the controller the right signal, you need to unplug the machine take the back off and look for a small 5mm pipe leading upwards, take it off and blow gently into it you should hear a click and one when you let the air out that means that the place you took it from is blocked with soap goo, unblock it with a pipe cleaner of meatal rod and replace the rubber pipe and try to run the machine again eric
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
LG Fuzzy logic 5.5 WFT552 goes to spin and then bangs around horribly before going back to the rinse cycle??? WHY?? Can anyone help please?
Could be broken spring unplug...remove top cover if front loader /inspect check drum.....make sure its level on the floor
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
12helpful
2answers
heatman101
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
