SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
SOURCE: jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
SOURCE: jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
SOURCE: Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
