Question about Symphonic Televison & Video
Code for symphonic sc519dd - Symphonic Televison & Video
Posted by Darlene J on
Need the codes for an rca coverter box for a symphonic tv
Here is the code for your symphonic tv that works for me. It is "0053."
Here are the steps:
1.
Press the "On" button on the symphonic TV to turn that set on.
2.
Hold down the TV button on the symphonic remote until all of the buttons on that remote flash.
3.
Type in 0053 code for the symphonic TV remote as you point the remote toward the TV.
4.
Press either the "Power" or "Pound" ("#") button on the symphonic remote to save the code
Jun 11, 2011 | Televison & Video
I recently got this tv from my church. Everything works fine except it only goes to aux and ch.2. I have no remote and there is no menu or set up button on the tv. So how do I make it go through all my...
It is difficult without remote. Try through the buttons provided in the TV front. Try the MENU button. Scroll through you will be able to get a solution.
Aug 19, 2010 | Symphonic SC519DD 19 in. TV/DVD Combo
Help
put it the mail address on not admitted
Jun 03, 2010 | Symphonic SC519DD 19 in. TV/DVD Combo
20 inch Symphonic TV/DVD Combo fuse keeps blowing immediately.
hello it sounds like theres a dead short unless you have a multimeter and oscilloscope a diagram and a bit of know how then yes you could do it youself i'd would get a quote for a repair good luck
shaun
Jan 17, 2009 | Symphonic SC519DD 19 in. TV/DVD Combo
Black Box at bottom of screen
The text mode has been activated either thru your cable/satelite box or your tv's. It is activated because the closed caption portion. If you think its because of your channel providers call them for the process to deactivate it . If it's your tvs check your menu's to make sure the closed caption portions are turned off. Good luck
Feb 22, 2008 | Symphonic SC519DD 19 in. TV/DVD Combo
Tv code
i can't find a setup code to remote setuo
Dec 26, 2007 | Symphonic SC519DD 19 in. TV/DVD Combo
No Sound
First of all try getting a Symphonic remote - http://www.miracleremote.com/ not that expensive. Then you can access all areas of the TV, including all sub menus and see how the audio is set-up.. Could be you have it in SAP mode, (Second Audio Programming), in which case you will hear nothing...
Bill
Nov 19, 2007 | Symphonic SC519DD 19 in. TV/DVD Combo
TV shuts itself off after a few minutes. Will also shut itself off if the DVD open/close button is pushed. Not sure if a DVD is in the machine or not. Any ideas??
I know that shortly after I purchased this tv mine also shut itself off occasionally. The owners manual says that if it is on dvd mode and it's paused or on an inactive menu or something for 15 minutes or so that it would shut itself off. If a dvd is stuck inside it may be causing this? I have no idea about the open/close malfunction.
Sep 29, 2007 | Symphonic SC519DD 19 in. TV/DVD Combo
Televison & Video Logo
163 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
