Cars & Trucks Logo
T
Tony Tan Posted on Nov 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need DRH-2415 DEFOND 15A 125V AC Switch l have a electric heater the switch is not working so l need fixing this problem
john h
Level 3:
Top Expert:
  • AC Master 29,494 Answers
  • Posted on Nov 23, 2016
john h
AC Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559441
Points
193449
Fixya doesnt sell products --either an appliance,heating,electric supply store or an online search for product
Mike J.
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 56 Answers
  • Posted on Apr 12, 2019
Mike J.
Expert
Level 2:
New Friend:
Greenhorn:
Answers
56
Questions
0
Helped
152889
Points
206
ZE-235-2 replaces Defond DRH-2415. You can find it on this link: https://www.ceilingfanswitch.com/product/ze-235-2-rocker-switch
2007 Pontiac Solstice convertible. The sound through speakers quit?
Fuse or Relay Number Fuse Rating Protected Component 1 40A Body control module - battery power in feed 1. 2 20A Power outlet main console bin. 3 40A Body control module - battery power in feed 2. 4 30A Fuel pump. 5 5A Powertrain control module keep alive power. 6 20A Powertrain control module power. 7 20A Canister vent solenoid. Evaporative leak control module. Exhaust gas heat recovery (hybrid electric vehicle). Tank pressure control valve (hybrid electric vehicle). Vapor blocking valve. Universal exhaust gas oxygen 11. Universal exhaust gas oxygen 21. Catalyst monitor sensor 12. Catalyst monitor sensor 22. Fuel flap door (hybrid electric vehicle). 8 20A Cooling fan relay coil. Battery interrupt box. Transmission oil pump. Auxiliary coolant pump. Engine coolant bypass valve. Electric A/C compressor (hybrid electric vehicle). Active grille shutters. 9 20A Ignition coils. 13 40A Front blower motor relay. 14 15A Transmission oil pump. A/C compressor variable clutch. Auxiliary pumps (hybrid electric vehicle). Electric A/C compressor (hybrid electric vehicle). Active grille shutters. 16 15A Windshield and rear window washer pump relay power. 17 5A Charge status indicator (hybrid electric vehicle). 18 30A Starter motor. 21 10A Headlamp red and blue flasher. 22 10A Electric power assisted steering module. 23 10A Anti-lock brake system module with integrated park brake. 24 10A Powertrain control module. Hybrid powertrain control module. 25 10A Air quality sensor. 360 camera with park aid. Rear view camera. Blind spot information system. Adaptive cruise control module. 26 15A Transmission control module. 28 40A Anti-lock brake system valves with integrated park brake. 29 60A Anti-lock brake system pump with integrated park brake. 30 30A Driver seat module. 31 30A Passenger seat motor. 32 20A Front media bin power point. 33 20A Rear cargo area power point. 34 20A Console end cap power point. 35 20A Console end cap power point. 36 40A Power inverter. 38 30A Climate controlled seat module. 41 30A Power liftgate module. 42 30A Trailer brake control module. 43 60A Body control module. 44 10A Brake on and off switch. 46 15A Battery charger control module (hybrid electric vehicle). 50 40A Heated backlite. 54 20A Visor control module. Run/start access feed. 55 20A Trailer tow park lamps. 57 30A Trailer tow battery charge. 58 10A Trailer tow backup lamps. 61 15A Not used (spare). 62 15A Headlamp washer pump. 64 40A Four-wheel drive module. 69 30A Front window wiper motor. 71 15A Rear window wiper motor. 72 20A Not used (spare). 73 30A Driver door module. 78 - Not used. 79 - Not used. 80 20A Not used (spare). 82 20A Not used (spare). 88 20A Rear blower motor. 91 20A Trailer tow lighting module. 95 15A Integrated spark control (hybrid electric vehicle). 96 15A Not used (spare). 97 10A Electric AC (hybrid electric vehicle). High voltage positive temperature coefficient heater (hybrid electric vehicle). 98 10A Traction battery coolant proportional valve (hybrid electric vehicle). 103 50A Rear power lug. 104 50A Rear power lug. 105 40A Not used (spare). 106 40A B+ feed. 107 40A B+ feed. 108 20A Spot lamp. 109 30A Passenger door module. 111 30A Body control module voltage quality monitor feed. 112 20A Not used (spare). 114 50A Not used (spare). 115 20A B+ feed. 116 5A Start access circuit. 118 20A Run/start feed. 120 15A Port fuel injectors. 124 5A Rain sensor. 125 5A USB smart charger 1. 127 20A B+ feed. Rear traffic advisor. Visor control module. 128 15A Not used (spare). 131 - Not used. 133 - Not used. 134 10A Delay accessory power. 136 20A Not used (spare). 139 5A USB smart charger 2. 142 5A Traffic cam. 146 15A Battery electronic control module. 148 30A Left-hand headlamp module. 149 30A Right-hand headlamp module. 150 40A B+ feed. 155 25A Transmission control module (hybrid electric vehicle). 159 15A DC/DC converter (hybrid electric vehicle). 160 10A B+ feed. Front warning lights. Strobes. 168 20A Low voltage service disconnect. 169 10A Coolant pump (hybrid electric vehicle). 170 10A Traction battery coolant pump (hybrid electric vehicle). Pedestrian sounder (hybrid electric vehicle). 177 10A Not used (spare).
Note: Spare fuse amperage may vary.
Passenger Compartment Fuse Panel
The fuse panel is under the instrument panel to the left of the steering column.
Note: It may be easier to access the fuse panel if you remove the finish trim piece.
Fuse or Relay Number Fuse Rating Protected Component 1 - Not used. 2 10A Moonroof. Inverter. Telematics control unit module. Driver door switch pack. 3 7.5A Memory seat switch. Wireless accessory charger module. Seat switches. 4 20A Not used (spare). 5 - Not used. 6 10A Not used. 7 10A Smart data link connector power. 8 5A Telematics control unit module. Hands-free liftgate actuation module. Power liftgate module. 9 5A Keypad switch. Rear climate control. 10 - Not used. 11 - Not used. 12 7.5A Climate control head. Gear shift module. 13 7.5A Steering column control module. Smart datalink connector. Instrument cluster. 14 15A Not used (spare). 15 15A SYNC. Integrated control panel. 16 - Not used. 17 7.5A Headlamp control module. 18 7.5A Steering wheel interface. 19 5A Headlamp switch. 20 5A Ignition switch. Telematics control unit module. Key inhibit solenoid lock. 21 5A Not used. 22 5A Not used (spare). 23 30A Not used (spare). 24 30A Moonroof. 25 20A Not used (spare). 26 30A Not used (spare). 27 30A Not used (spare). 28 30A Not used (spare). 29 15A Integrated computer screen. 30 5A Brake switch signal. 31 10A Terrain management switch. Selectable drive mode switch. Transceiver module. 32 20A Audio control module. 33 - Not used. 34 30A Run/start relay. 35 5A Low gear select. 36 15A Park assist module. Image processing module A. 37 20A Not used (spare). 38 30A Left-hand rear power window. Right-hand rear power window.
I got a new brake light switch for my 1999 Lincoln town car and it still won't work
Did you check fuse , battery voltage to the brake lamp switch ?
VISUAL INSPECTION CHART Electrical
  • Damaged multi-function switch.
  • Damaged stoplight switch.
  • Circuitry open/shorted.
  • Open fuse.
  • Fuse junction panel Fuse 16 (15A), Fuse 1 (15A), Circuit breaker 12 (18A).
  • Damaged connectors.
Y need book for fuse box
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat,
i copied this off another post hope this helps
1helpful
Fuse Box Diagrams (Inside and Engine) for 2009 Volkswagen Tigua?
Attached are the diagrams requested - good luck!
Fascia 1
Fuse, (Amps), Circuit
F1 -
F2 -
F3 -
F4 -
F5 -
F6 -
F7 -
F8 -
F9 (5A) Supplementary restraint system (SRS) control module
F10 (10A) Four wheel drive control module
F11 (5A) Parking aid control module, self-parking system control module
F12 (10A) Gas discharge headlamp control module (LH)
F13 (5A)
ABS/ESP system, AC system, anti-dazzle interior mirror, heated windscreen washer jets, seat occupation control
module, transmission control module (TCM), reversing lamps, engine management system
F14 (10A)
ABS control module, engine control module (ECM), heated seats, power steering control module, suspension
control module, trailer control module, AC control module, instrumentation control module, CAN data bus
gateway control module
F15 (10A)
Auxiliary heater, data link connector (DLC), parking brake control module, engine management, headlamp
direction control module
F16 (10A) Gas discharge headlamp control module (RH)
F17 (5A) Instrument panel
F18 (10A) Mobile telephone control module, multimedia control module
F19 (10A) Steering column function control module 2
F20 (5A) ABS control module, AC system, transmission control module (TCM)
F21 (15A) Door function control module, left rear, door function control module, right rear, multifunction control module 2
F22 (5A) Alarm system, multifunction control module 2
F23 (10A) ABS/ESP system, AC system, data link connector (DLC), rear view camera control module, headlamp switch
F24 (10A) Door function control module, driver, door function control module, passenger
F25 (20A) Transmission control module (TCM)
F26 -
F27 -
F28 (40A) AC control module, auxiliary heater
F29 (15A) Rear screen wiper motor
F30 -
F31 (20A) Auxiliary power sockets, cigarette lighter
F32 -
F33 -
F34 -
F35 -
F36 -
F37 -
F38 (10A) Steering column function control module 1
F39 (20A) Headlamp washers
F40 (15A) Trailer control module
F41 (15A) Trailer control module
F42 (20A) Trailer control module
F43 (25A) Sunroof control module
F44 (25A) Parking brake control module
F45 (25A) Heater blower motor, heated rear window
F46 (30A) Door function control module, driver, door function control module, passenger
F47 (30A) Door function control module, driver, door function control module, right rear
F48 (15A) Fuel pump (FP)
F49 (20A) multifunction control module 2
F50 (25A) Parking brake control module
F51 (40A) AC/heater blower motor control module
F52 (30A) Seat heater control module
F53
(20A/30A)
Headlamp washers
F54 (30A) Auxiliary power sockets
F55 (15A) Lumbar support adjustment
F56 (15A) Suspension control module
F57 (25A) Sun blind control module
F58 (1A) Trailer warning lamp
F59 (20A) Multimedia control module
F60 -
Fascia 3
in engine bay
Fuse (Amps) Circuit
F1 -
F2 -
F3 (5A) Multifunction control module 2
F4 (30A) ABS/ESP system
F5 -
F6 (5A) Instrumentation control module, steering column function control module 2
F7 (40A) Ignition main circuits
F8 (25A) In-car entertainment (ICE)
F8 (25A) Voltage converter
F9 (5A) Mobile telephone control module
F10 (5A/10A) Engine control module (ECM)
F11 (20A) Auxiliary heater control module
F12 (5A) CAN data bus gateway control module
F13 (15A/30A) Engine control module (ECM)
F14 (5A) Engine management system
F15 (5A/10A/15A) Fuel pump (FP), AC compressor clutch, engine management system
F16 (30A) Multifunction control module 2
F17 (15A) Alarm system horn
F18 (30A) Audio system
F19 (30A) Windscreen wiper motor
F20 (10A) Engine management system
F21 (10A/20A) Engine management system, fuel pump (FP) control module
F22 (5A) Clutch pedal position (CPP) switch
F23 (10A) Engine management system
F24 (10A) Engine coolant blower motor control module, engine management system, engine coolant heater
F25 (40A) ABS/ESP system
F26 (30A) Multifunction control module 2
F27 -
F28 (50A) Glow plug control module
F29 (50A) Electric seats
F30 (50A) Ignition switch circuits
Location Component
1 Petrol: Engine control (EC) relay 1
1 Diesel: Ignition main circuits relay
2 Petrol: Engine control (EC) relay 2
2 Diesel: Engine control (EC) relay
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Hope this helps
--N
2helpful
Abs fuse
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump2.gif relay and RAP module
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
10helpful
4answers
I need a fuse box diagram for a 2003 Ford Explorer Sport
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout- I think this is a good sticky candidate--
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
1helpful
Blower for heater and ac not working. fuse and
The heat selector switch in the heater control knobs is the only electric style in the group. The rest are cable driven. It may need replacement.
Ac problem
I just fixed mine. same problem, no ac light no fan. inside the heater control assembly there is a electric wiper arm on the fan switch. This arm connects all power for fan and ac. Mine broke out of the fan control switch. Dash is not too much problem to get out. Have to pull top dash center section out by puching forward and lifting out. pull all screws on center dash counsel. remove radio, two side covers that hide screwsand lower trim that holds emergency flasher switch. remove cables from heater control and wires and remove. Took me about an hour. The code on radio will need to be reset so make sure you have that handy. Hope this helps..
Top AC Experts
old marine
old marine
vince
Are you an AC Expert? Answer questions, earn points and help others
