Question about Canon imageRUNNER 2016 All-In-One Laser Printer
My canon ir 2016 is showing adjusting waiting to scan after I want to do photocopy Please help me
Posted by Amaoko Addo Seth on
AFIFUL HAQUE MUFTI BARBHUIYA
    New Friend:
  • 23 Answers
Dear, check all the ccd flat cables of scanner unit and dc boards back side and replace them which are faulty due to long time which lost the metallic strength for which this issue comes .One flat cable is fitted from scanner lamp unit to its board which is long cable and two flat cables are fitted with this scanner board to back side pcb which are long and another one is connected to two pcb boards at back side one comes from mother board to other board,
Posted on Nov 09, 2017
5 Related Answers
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: Canon IR C3200N scan with MAC OSX
Hi!
Please download the drivers from the Canon Website.
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Posted on Feb 08, 2009
Sunil Rathod
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
Sunil Rathod
  • 199 Answers
SOURCE: Error E007 canon IR 2016
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
To clear the error, execute the following in service mode: -
COPIER>FUNCTION>CLEAR>ERR.
to open service mode press star press 2 and 8 key same time then press star again.
Is there a fault in the fixing film edge rotation detection mechanism?
YES: Replace the fixing film unit.
Posted on Mar 05, 2009
Anonymous
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Posted on Apr 09, 2009
Anonymous
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Posted on Apr 20, 2009
Language setting to English in canon ir2016i
Dear User,
press additional setting in canon ir 2016 photocopier.then choose language setting tab now select the language by pressing + or - button then save it. it may work.
Oct 16, 2016 | Canon imageRUNNER 2016 All-In-One Laser...
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
Canon ir2016 show
PROBLEM WITH CANON 1R 2016 PHOTOCOPIER
SHOWING ADJUSTING WAITING FOR SCAN
PLEASE HELP ME HOW TO FIX THIS
Mar 22, 2012 | Canon iR 2016i Black and White Copier
Canon ir2016 photocopy machine printer software
i want to get the Canon ir 2016j photocopy machine drivers
Oct 20, 2010 | Computers & Internet
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
Canon imageRUNNER 2016 All-In-One Laser Printer Logo
347 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
