Question about GE Advantium 120 Convection/Microwave Oven
GE profile Advantium Oven- Microwave- Model # SCB1000KBB01
When I am cooking after dark, the control panel is so dark it can not be read.My eyes are in good shape- I have searched thru the folders and instructions to see if there is a switch. Perhaps you know where it is. I would be thrilled to stop squinting or getting a flash light. My thanks to you for an answer to my problem. Phyllis White- Pampa Tx
Posted by sillyph on
Devabhakthuni Venkateswara Rao
    Champion:
  • 225 Answers
Check control circuit, and display circuit.
Posted on Nov 20, 2007
Microwave control panel dark
Since you posted this under the WMH32517AT category, I'll assume that's your model number. If not, feel free to e-mail me (below).
The function of the door switches is to prevent the oven from running when the door is open.
If the switches fail in a certain way, it can cause the fuse or breaker to blow. That's by design.
Some models have a line fuse and another fuse for the controller low voltage transformer.
There is a technical sheet hidden behind the grille or behind the controls. It's very helpful in locating components and testing, etc.
Your door switch mounts need to be inspected to be sure they're not loose, misaligned, or damaged. If so, they'll need to be realigned or replaced as needed.
The hook-like "latch heads" protruding from the door must be under spring tension and must move up and down freely in order to activate the door switches.
It sounds like your door switch is stuck, and you can order a universal type here.
Most door switch problems are caused by slamming the door or opening the door while it's cooking instead of hitting the "Stop" pad first.
At my Web site, I have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
The support page for model WMH32517AT is here. It has the owner's manual, installation instructions, exploded views, and parts lists.
You can order any needed Whirlpool parts from the Pros here, my favorite affiliated supplier.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 05, 2017 | Whirlpool WMH32517AT Over the Range...
Whirlpool microwave mh7110xbb-4
Judging from what you have described, it appears the unit is now finally dead, dead, dead. Did Google search and found a bunch of them Good luck.
Aug 26, 2017 | Microwave Ovens
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Does not heat food
If the inside light, cooling fan, and turntable all come on when you press "Start" to cook, but it does not heat, then you have a defective high voltage section part (HV fuse, magnetron, etc.)
If the above 3 components do not all come on when you try to cook, then it\'s probably just a bad bottom door switch or mount.
My help file on door switches is here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel which is
very helpful when troubleshooting, testing, and locating
components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt
we have a video
over the range control panel assembly in under 5 minutes.
This additional disassembly information may apply:
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they\'re removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
(There are three L-shaped clips that fit into a slot to hold bottom of the vent)
Then remove one screw (which holds the control panel in place) near the top of the control panel.
Once that screw is removed the panel tilts out so you can disconnect the wires and then slip it out.
Be sure to mark and/or photograph your wires so that each one gets back exactly where it was after the repair.
Reassembly is accomplished by sliding the L-shaped keepers in place, then sliding the vent grill to the right and pushing it into place.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven
here.
We\'re
happy
to help you with free advice and we\'d appreciate your thoughtful rating
of our answer.
Nov 27, 2012 | GE JVM1850 1000 Watts Microwave Oven
My GE JE1640 microwave has the following problem: I go to clear, time cook, start & the timer counts down, the light comes on, but the fan doesn't come on and there is no microwave cooking. I have...
What do you mean you checked the door interlocks? did you remove them and take a resistance reading? Or do they look like they are there? I am sticking with the door switches as the problem..
Oct 28, 2017 | GE JE1640WA/GA Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
I have a MG208 Combination Microwave Oven and Grill. I got it from Tesco about a year ago. Yesterday I was cooking something in it for 10 minutes but when the clock reached zero it wouldn't turn off. I...
Please go online and type in your make and model, and begin searching for a dealer or manufacturer's web site.
It appears your controller or the control panel is broken, and you should be needing a new control or control panel.
You will need to not use it again until it is fixed, because of danger of fire.
God bless your efforts.
Jul 11, 2017 | Microwave Ovens
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
Whirlpool Micrwave, model #mh6150xls-1
Since you tested the door switches (my number one suspect) I would think you have a bad relay or a bad connection on the control panel circuit board. We repair these nationwide for $32.50, which is usually economical for most models. Just to make sure you have checked the door switches thoroughly, you can find my helpful text file called "doorsw.txt" via a Google search. It has important safety information and tips.
Oct 24, 2006 | Whirlpool MH6150XLS Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
250 people viewed this question
Top GE Microwave Ovens Experts
Jimmy
Poppa Maddo
Poppa Maddo
gbob59
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
