Ovens Logo
Question about Belling Ovens
I have a Belling Format Cooker model 647SS, but there are no temp figures on the dials or panels,am finding it impossible to download the manual. How can I go about using the OVEN
Posted by Gerry Shallow on
  • Marvin
    Marvin Nov 22, 2016
    Hi Gerry Shallow, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Gerry Shallow
    Gerry Shallow Nov 22, 2016
    What more can I say----where can I locate temperature settings? How do I use the oven?
5 Related Answers
Anonymous
  • 359 Answers
SOURCE: MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
sounds like the fan element this link will help http://www.ransomspares.co.uk/elements.asp?search_fd6=XOU252
Posted on May 26, 2008
jackdaniels1
SOURCE: Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Posted on Aug 01, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Belling 592SS self clean panels need replacing
Go to:
www.belling.co uk and follow the links
You should find what you are looking for
Posted on Dec 08, 2008
Anonymous
  • 10 Answers
SOURCE: Where can I obtain an instruction manual for a
Check fuses first. locate the model number and call manufacturer's toll free hotline.
Posted on Sep 03, 2009
Anonymous
SOURCE: how do you reset the clock when you switch on a
belling single oven. how do you reset the clock
Posted on Mar 19, 2010
How can I obtain an Instruction Manual
Manuals
Link to Belling site to download manuals
Sep 18, 2014 • Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Free standing belling cooker model numbers
try pushing 2 buttons on left and 2nd button in from right side
push left ones first then the other! should stop it.
Could try pulling buttons out and then replacing them best is to consult a local engineer!
warmest regards
Richard The Repairman
Mar 28, 2014 • Ovens
Cooker problem
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Go to:
Cant find the model number on a Belling Format cooker
Hi.
Try looking inside the oven, or at the bottom front
Nov 28, 2008 • Ovens
15helpful
3answers
Top Belling Ovens Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Belling Oven Expert? Answer questions, earn points and help others
