Question about Brother MFC-7820N Printer
I have a brother MFC-7820N fax machine, i tried to connect the fax machine to the plug on the wall so I cannot send any faxes.
I also want to change the language to English from German, I cannot seem to be able to that?Please help!
Posted by Loucas Kazamias on
5 Related Answers
Anonymous
SOURCE: Brother MFC 7820N
how do i program one touch dialing on my brother MFC 7820N fax machine
Posted on Sep 10, 2008
Anonymous
SOURCE: Not able to send fax to an eFax number
I've had the same problem before. I don't know if it will solve your problem directly but I can offer a work around or two.
1. I have an efax number but with a company called callwave.com , I fax stuff to other customers using callwave and my MFC 7820n completes each fax successfully. So if you can get yourself a callwave efax number you can fax to yourself and forward fax as an email to your intended party.
2. Or, you can use your mfc 7820n to scan your fax docs as a pdf directly to your computer and then emailing them to your intended party.
Unfortunately it might be a brother issue because at the office when I use the hp fax machine instead of the brother machine, the hp faxes to efax numbers without a problem.
Posted on Oct 22, 2008
Anonymous
SOURCE: Fax Confirmation Page
I used another website that allowed me to look at a printable version of the manual I needed.
Posted on Dec 05, 2008
jonags3
Jonathan Agawin
  • 83 Answers
SOURCE: change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
Posted on Dec 11, 2008
Anonymous
SOURCE: cannot send or receive faxes
Try to call from your fax if u make calls then the line is ok,if not check the line.check the cable have 4 pin ,Take the user settings in the reports menu,check and confirm the mode is "tone" if its "pulse" change it as Tone.
Posted on Jun 01, 2009
Im using the Brother MFC 7820n at a hotel. how do i fax? i've tired 9+1+area code+the number, 9+area code+the number and a few others but nothing seems to work, what am i doing wrong?
Depends on the hotel.
Some have a specific dedicated line that allow direct dial (no 9). Some block long distance calls and required the use of a calling card.
Otherwise, dialing 9 should work.
Can you hear the dial tone? What kind of sound do you hear when it fails? Is ti list a fast busy signal? Or do you just hear nothing?
If they have the speaker off, try to call your cell phone from the FAX just to see if it can make an outbound call at all.
Also, try tracing the wire from the fax machine. Make sure it is plugged into LINE and not PHONE. (or the jack with the picture of a wall jack, not a picture of a phone). Some hotel patrons disconnect FAX machines to use the phone line on their laptop modem and then neglect to properly reconnect the fax machine. Also make sure it is connected at the wall.
Apr 20, 2011 | Brother MFC-7820N Printer
Unable 2 send or recive fax
Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 15, 2010 | Brother MFC-8220 Fax
Cannot send or receive faxes
May 05, 2009 | Brother MFC-7820N All-In-One Laser Printer
Can't send faxes
First disconnect the fax from the phone line. take regualar phone and plug into the wall outlet. dial thefax number. and listen for the the fax tone.
if the line is good. connected the fax and do the follwoing:
Manual Fax mode:
Press the fax icon (should turn green)
Load the document on the scanner glass.
Dial the fax number
press Mono Start.
if not, try to find a good phone line to use.
Feb 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
Dec 01, 2008 | Brother MFC-7820N Printer
Brother MFC-7840W fax will not work
Plug a regular phone into the wall jack and listen for a dial tone.
Phone cord should be connected to the LINE port of the fax.
Do you have DSL?
Unplug power cord for 10 seconds.
Oct 17, 2008 | Office Equipment & Supplies
Brother MFC 7820N
Sep 09, 2008 | Brother MFC-7820N Laser Printer
Sep 05, 2008 | Brother MFC-7820N Printer
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at [email protected]:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
71 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
