Question about 3Com Computers & Internet
How do I change the display name on a 3com 3102 ip phone from and old user to a new one?
Posted by Jeff Hotchkiss on
2 Related Answers
micromaster
micromaster
  • 3614 Answers
SOURCE: 3com 3102 not working
try 192.168.2.1 / 192.168.2.0 / 192.168.0.1
hope it works.
enjoy
Posted on Feb 15, 2008
NBX_Tech
NBX_Tech
  • 58 Answers
SOURCE: When someone call 3Com NBX 3102 IP Phone we cannot hear
If the phones are only 6-8 months old you should be calling 3Com. those phones have a 1 year warranty and once you register them they will help you troubleshoot and replace them if needed. Can you provide more detail? Do you have any network issues while this is happening? Does speakerphone work but the handset doesn't?
Posted on Jul 26, 2010
Web page + 3102
You can't web to a 3102 phone, only the phone system. If you don't know what the IP address is on the phone system, you will have to get a serial cable (null modem cable) DB9 male to DB9 female and connect to the console 1 of the phone system. You will need a terminal emulator program and connect at 9600, 8, none and 1 for the settings. Type nbxIpConfig (case sensitive) and hit enter. The IP address will then be shown. If this is not what you were asking, please explain.
Feb 19, 2014 | 3Com NBX 3102 IP Phone
hope it works.
enjoy
Feb 15, 2008 | 3Com NBX 3102 IP Phone
Reset 3com 3102
Hi Chirag,
On the web interface, use
1 Click System Maintenance > Purge Data.
2 Click Purge Database
This ll do fact reset.
HTH
-Karthik.
Oct 02, 2012 | 3Com NBX 3102 IP Phone
How to reset a 3com phone
You'd have to reboot the phone, and press the white dot 'Program' button within 30 seconds of reboot, then use the arrows to scroll down through the menus to Advanced settings, and find Eeprom reset to default, and choose that. *Note- This will reset all values of the phone. If it's Ethernet Only, it's fine. If the phone is using a Static IP, it will also clear the IP addressing on the phone*
If you are talking about resetting the phone from a user profile perspective it is different. You can reset the voicemail password under the system maintinence, password administration and select user password in the drop down box. After the password has been reset (to the extension number) they can log in and change the recordings and password. You will also need to then go to the users tab and change the name.
Jul 03, 2012 | 3Com NBX 3102 IP Phone
3Com 3102 phone dial tone but won't dial out
As long as someone hasn't been poking around in the phone system, this is a phone company issue. I have seen this many times and it has always been a carrier issue. Typically with PRI's or integrated access analog lines.
May 08, 2012 | 3Com NBX 3102 IP Phone
How do you change the time on the display panel
You have to change the time on the phone system by logging in as administrator. Once it is changed it will update the time on all of the phones at the same time. Remote IP phones are a little different in that they only sometimes get the correct time from the system when they are booted and connect to the system.
Jan 30, 2012 | 3Com 3102 IP Phone
I get the message: 3Com Model 3102- Wait for NCP M We have never seen this before and it is after a power outage. Our server is running. What is NCP?
Hello.
NCP stands for Network Call Processor. There is a problem with communication. Since your server is running, reset your router (disconnect power, wait a few minutes, then reconnect) that supports your IP phone.
Hope this helps.
Aug 29, 2011 | 3Com NBX 3102 IP Phone
When someone call 3Com NBX 3102 IP Phone we cannot hear them talking, but they can hear us. I tried it on three 3Com systems and same thing happens. We get problems like these often and we are just...
Apr 29, 2010 | 3Com NBX 3102 IP Phone
Cant connect additional 3102 to nbx. Please help!
3102 phones require group 2 licenses purchased from an authorized NBX reseller. if you don't have enough the system will not allow the phone to be discovered. You can check this unler the licenses tab while logged into the phone system as administrator.
Jun 25, 2009 | 3Com NBX 3102 IP Phone
3com NBX phone number of rings setting problem.
Delete the MAc Address from the system and delete the user account. Re add the phone.
Feb 12, 2009 | 3Com NBX 2102 IP Phone
Computers & Internet Logo
224 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Sheldon Dedek
Vincent G
Vincent G
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
