Question about Kenmore Coffee Makers & Espresso Machines
I changed charcoal filter on my Kenmore coffeemaker but the reset filter light is still on.
Posted by Deborah Sechman on
3 Related Answers
Anonymous
  • 13 Answers
SOURCE: Kenmore Elite coffeemaker water filter
http://www.kenmore.com/shc/s/p_10153_12605_00869768000P?filter=Price%7C%240-260%5E&vName=Appliances&cName=Small+Kitchen+Appliances&sName=Coffee%2C+Espresso+%26+Tea+Makers
Try here. Hope this helps.
Posted on Jan 08, 2008
Anonymous
  • 427 Answers
SOURCE: Coffee maker not brewing after changing water filter
Dis asselble the coffee maker and make sure there arent any coffee grinds stuck in the grinder, this is the usuall problem to coffee makers after some time.
Posted on Apr 29, 2008
Anonymous
  • 3 Answers
SOURCE: I am looking for a
If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack)
http://www.sears.com/shc/s/p_10153_12605_00869768000P
Posted on Nov 28, 2010
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
I need a replacement filter for my kenmore coffee maker item#69768
Nov 13, 2010 | Kenmore DCC-KE12 Coffee Maker
I am looking for a charcoal filter #69768 for my coffeemaker model #80666 where can I order?
Oct 26, 2010 | Kenmore Coffee Makers & Espresso Machines
I lost my manual and don't know how to clean the machine. I have hard water so there are deposits near the water tank.
Instructions vary a bit according to machine, but a safe bet is to use a mix of 1/3 white vinegar to 2/3 water. If you are uncertain, you can always type the name or model number for the coffeemaker into a search engine along with the words "owner's manual" or "user guide" or words to that effect. The other option is to visit the manufacturer website. There should be a search box or a "support" section of the website where you can look up your coffeemaker and view a PDF of the owner's guide (the PDF will either download to your desktop or open in your web browser).
In general:
1) Put the filter basket in place and set the machine up as if you were going to brew coffee. 2) If there is a charcoal water purification filter in the machine, take it out.* 3) Run the aforementioned vinegar solution through as if you were brewing coffee. (Just hit the brew button after adding at least 6 carafe cups of diluted white vinegar.) 4) Wait about 10-15 minutes to let the machine cool down and then "brew" the vinegar solution through again if it has been a long while and the deposits are particularly severe. (Note: Some owner's manual will have you pour the vinegar that is in your carafe back into the water tank and run it again, and others will call for you to discard the first batch and brew through a fresh solution.) 5) Follow the same instructions as written above but this time with a full carafe of fresh water (no vinegar). Repeat 2-3 times to rinse out the vinegar odor/taste. 6) To clean your carafe use hot water, baking soda and vinegar. Place the carafe in the sink, fill with hot water, pour in some baking soda and add in a 1/4 cup or so of white vinegar. The foaming action will help release stains and stale coffee odors. If the stains are particularly severe, dissolve a tablespoon or so of liquid dishwasher detergent in extremely hot water — be careful! — and pour it into the carafe. Let it soak for an hour or overnight and rinse with hot water about 4-6 times to make sure the solution is entirely rinsed out.
* Tip: If your coffeemaker has a water purification filter, do not reinstall after cleaning your machine if you can't recall the last time you replaced it. A worn out charcoal filter cannot be cleaned, may slow down the brew speed or make the coffee taste "off". The only option is to remove or replace it with a fresh water filter. This is only applicable if your coffeemaker came with a charcoal water filter. If present, you will typically find it inside the water tank inside a plastic holder of some sort.
Mar 05, 2010 | Starbucks Barista Quattro Coffee Maker
Coffee not tasting good
To make the self-clean light go off, just unplug the coffeemaker for longer than 20 minutes. As far as not tasting right, did you try flushing the vinegar out of the coffeemaker using plain water, or water mixed with 1 tbsp lemon juice per cup? Also, get rid of your current charcoal water filter - after time, it will disintegrate, and your coffee will have a hint of charcoal.
Apr 11, 2009 | Cuisinart DCC-1200 Coffee Maker
Find water filter replacement part # 69768 for Kenmore Coffeemake
I returned the coffeemaker to the Store where I purchased it and exchanged it for a model by a different manufacturer which contained clear instructions as to how and where to obtain replacement parts.
Apr 09, 2009 | Coffee Makers & Espresso Machines
Cuisinart dcc-1150 coffeemaker
To replace water filter: Pull water filter holder out of reservoir, snap open, insert new charcoal water filters (can be ordered from Cuisinart or purchased froma store like william-Sonoma)
To clean machine: Run 2 cups water and 2 cups distilled white vinegar through machine like you would normal coffee.
To get rid of annoying self-clean lite: unplug machine from wall outlet for 20 minutes or longer.
-Tha Mp3 Doctor
Oct 24, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Aug 01, 2008 | GE 106591 Coffee Maker
Oct 08, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
78 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
gbob59
Jude24
ray gallant
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
