Home Logo
Anonymous Posted on Nov 21, 2016
How do I change when the dinger chimes ?
I have a Regulator 31 day wall clock that dings once on the hour and multiple times on the hour, for example at 6:00 it dings once and at 6:30 it chimes 6 times
5 Related Answers
John McCaffrey
  • Posted on Jul 03, 2009
SOURCE: Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jul 29, 2009
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Anonymous
  • 23 Answers
  • Posted on Nov 04, 2009
SOURCE: I have a radio Shack Atomic Wall Clock 63-1438 and
Most atomic clocks simply receive the National Institute of Standards and Technology (NIST) time signal. They do not all allow for daylight savings time changes as not all areas use it.
You will have to adjust manually.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 03, 2010
SOURCE: i have a forestville wall clock with the pull down
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Anonymous
  • Posted on Nov 10, 2010
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Seth Thomas wall clock doesn't chime on the quarter, half or three quarter hour but does chime on the hour
Please change the time of your wall clock back 1 hour and check if the other 3 chimes return. There should be knobs on the side of the clock to help you do this. If not on the side, then please check on the back. Since you've already checked the settings and ruled them out as the cause of the issue (as well as the batteries), you might need to perform a factory reset on the clock if the steps I mentioned above fail.
Thank you.
Model 611-220 How do I reset? Chime is off. When it is 2, it chimes 7 as an example. I can't get in front to manually move hour and minute hand separately. I have only the dial in back.
Will the dial at the back turn the hands backwards? if it does set the clock at 12 o'clock then turn back to eleven . wait a minute or so then set back to twelve. if this changes the dings keep doing this till it is properly set. Not sure if this will work for your clock as mine is a different make. Try it once and see if it works. If it does not change do not keep playing with it.
Feb 27, 2019 • Chime Home
1helpful
I have a polaris 31 day grandfather clock that is chimming 1 hour and 15 minutes to soon. (Example: real time is 8:45 and it is chilling lime it is 10:00 o'clock. How do I fix this? Thank you.
Hi i owned a grand father clock and it had a reset button for the chimes BUT that was if it was an hour or two fast or slow It's only a guess because your clock is 1.15 slower than the chimes, You should be able to remove the hands off the face (note exactly where they were) and replace them 1.15 forward, NOTE you won't be able to push them 1.15 forward as the chimes will follow... I hope i haven't confused you... CHEERS..
Own bulova b1987 bardwell clock where chiming is off for the proper hour. Example, at 1pm there will be 2 chimes and so on and so forth. How can I fix this?
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Oct 31, 2015 • Home
How to Set the time on a waltham 31 day wall clock?
Dec 12, 2013 • Home
2answers
My clock chies 2 hours behind
If the clock is a mechanical clock there are 2 ways it can be fixed. You need to take the hands off the clock and gently replace the hour hand to the hour it strikes/chimes replace the minute hand and then gently clockwise ONLY move the minute hand to each hour letting it strike/chime the hour it is on. If this does not work there is another way and you can email me Yvonne. [email protected] for more information. Mechanical clocks only.
3helpful
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 • Watches
5helpful
3answers
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
A few days ago the minute hand came off my HM Regulator keywind clock. I put the hand back on and the clock is keeping time, but the chime is not in sync with the time; re: it strikes the hour on the half...
yes
the positon of minute hand not sync with chime strikes.
you fix the minute hand as 15.minute slower and adjust the current time using time adjuster switch not with minute hand ok.
try it and solve it
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
