Question about Samsung Cameras
What does a leaf showing on a flip Samsung phone mean?
The battery needs charging a LOT even though it is a new battery, and a picture of a leaf shows up on the screen.
Posted by Karen Overton on
Cliff Sheldon
    New Friend:
  • 10 Answers
Power saving mode.
Posted on Nov 20, 2016
My Samsang CE 0168 just when dead and not showing that it is charging. What could be the problem and can a new battery for the phone be fitted or?
When some batteries go bad they will not even take a charge and no charging indication is manifested. Yes, I would replace the battery.
Sep 16, 2016 | Samsung Cell Phones
Straight talk samsung galaxy proclaim cell phone. Turns off and on by itself. Will say battery critically low but when plug in battery shows not that low. cant do browser or apps unless plugged to charger....
Its battery is weak. Even though it shows full; when the O/S loads, the CPU of the phone will take large amount of current, and the battery is unable to supply it during that time. In short; the current storing capacity; at least 1.2AMPs, should be there with the battery, but now there is not. It won't hold charge; in terms of current.
Replace the battery with new one. There is no other problem to your phone.
Gopakumar Gopalan Google
Aug 07, 2014 | Cell Phones
Galaxy wont charge even though hit shows that it is?
Not sure if u have insurance warranty. But Galaxy phones have a known charging port issue. I have gone thru many of these phones. I also own one I modded a new charging port and it works great. So Imo I would say cheap parts installed. But if you have never done a soft reset yet try that first. But do the soft reset (5) times. In a row. Then plug it in. Hope you got it solved either way.
May 19, 2014 | Samsung Galaxy S GTI9000 Smartphone
IPhone 3GS battery replaced, connected to itunes via USB cable and synced, battery percentage indicator showed a power plug didn't start charging. Charger removed and over night the battery seemed to have...
Is the replacement battery an original equipment battery? I bought an aftermarket battery for my Samsung and the phone will not recognize the battery even though the specs are identical. Nice trick by Samsung. See if I ever buy another product of theirs again. Anyhow try putting the old battery back in and see if it will function while plugged in. Otherwise head to the phone store.
Nov 01, 2013 | Cell Phones
Phone shows samsung logo and then goes blank
did you get your phone wet? same thing used to happen to my samsung prevail when i accidentally dropped it in a bucket full of water, after maybe 3 days of it doing that (showing logo, then black screen) it finally died, i put a brand new and charged battery but it didn't work, my friend who works for sprint, told me smart phones sometimes "burn out" meaning they overheat and eventually give out... I just bought me a new one when he told me that, cause I did use it alot and it did tend to overheat. Check your battery for any leakage, for some reason mine was...
Aug 17, 2012 | Samsung Focus i917 (8 GB) Smartphone
What does the battery with a line through it mean when it shows up on the front screen and the phone won't charge?
This battery line indication means the battery don't have enough performance to accept power voltage anymore,better replace a new one,be sure to buy original battery for better performance.
Aug 06, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Samsung SGH D807 Charging Problem and no screen display
Have you try to use another similar charger to charge your phone to see if it ill charge? because it could be that your charger is bad,. But if you have done that and it is same thing, it means the charging port of your phone is malfunctioning, that is why you have to use repetitive effort before it can charge.
Your battery is not charge due to the bad charging port of your phone, so your phone battery can not hold charge.
To resolve 1 and 2 problem of your phone, all you need to do is to change the charging port of your phone in other for your phone battery to charge and for your battery to charge.
Replace the charging port as said and you will see that your phone battery will charge.
For your screen, is it that the entire screen is black that you cannot see anything, not even text or see names from your contact? if it is, what you need to do is to change the flex on the the screen of your phone and you will see that your screen will display as you want it.
Take care.
May 04, 2010 | Samsung SGH-d807 Cellular Phone
Won't charge
if the charger is good, then there is something wrong with the charging port or the battery.
If the battery is very flat before you charge, the charger would not be unable to wake the battery because the battery cell is weak. Its only a desktop charger that can wake the battery cell.
So, test your phone with another good battery, and if it still does not charge, then the charging port is bad as I said earlier.
Best wishes.
Jan 12, 2010 | Samsung M220 Cell Phone
Cameras Logo
35 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Eric
Are you a Samsung Camera Expert? Answer questions, earn points and help others
