Message showing LSU Error - Office Equipment & Supplies
Posted by Bruce Howitt on
HEMANT GROVER
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Office Equip... Expert
  • 171 Answers
This is a laser scan unit error, either lsu reuires services , else needs replacement.
Posted on Jul 31, 2017
5 Related Answers
Rick Kasper
  • 2072 Answers
SOURCE: lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Posted on Dec 31, 2007
The Machine
Dean Joly
  • 788 Answers
SOURCE: LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
Posted on Jan 14, 2008
Anonymous
SOURCE: lsu error pour samsung scx-4100
Please kindly help me to sole the problem Lsu of my printer samsung scx-4100
thanks
Posted on Sep 20, 2008
Anonymous
SOURCE: Error message w/Samsung ML 2150 Laser Printer - Engine LSU Error
Your Laser unit at the top section where the paper exit is faulty. You have no choice but to change it.
Posted on Nov 27, 2008
Anonymous
  • 3 Answers
The Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge inside the machine could be dirty. The mirror motor in the LSU could be bad or needing cleaned so it spins better. Laser diode could be bad.
Posted on Feb 03, 2009
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Engine LSU error printer model samsung ML2150
how can over come from LSU error problem in samsung all in one machines
Jan 21, 2010 | Samsung ML-2150 Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
LSU ERROR MESSAGE ON little screen when photocopying
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Mar 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Nov 11, 2008 | Samsung ML-2150 Laser Printer
Printer Problem
What model printer is this? The C2424 does not have a laser.
Are you 100 percent sure it is a model C2424?
There is no LSU status code for that machine.
May 14, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Jan 02, 2008 | Dell 1600n All-In-One Laser Printer
Lsu error
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
134 people viewed this question
Ekse
Marvin
Marvin
