Question about Chevrolet 2012 Chevrolet Sonic
I have a 2012 sonic with a check engine light on, had the codes read and they said replace fuel injectors. what is the correct fuel pressure this car should have?
Posted by Michael Broad on
5 Related Answers
Anonymous
SOURCE: 2000 chevy blazer, truck cranks
Does your battery go dead?
Posted on Dec 18, 2008
Anonymous
  • 5 Answers
SOURCE: 1987 chevy engine problem
you have to reset base idle see manual at library for procedure
Posted on Jul 19, 2009
pippall
Philip Long
  • 1486 Answers
SOURCE: 1987 chevy S10 engine idle problem
relace the throtle air idle valve.The temp switch will allso cause this problem.
Anonymous
  • 32 Answers
SOURCE: po452 trouble code changed sensor engine light
you might try unhooking the battiey for 20min both + and - posties cuz that will force the computor to have to resest only if you have addressied the fuel pressure problem which taht would most likly be your filter which isn't all that much
Posted on Sep 21, 2009
Richard Delahant
  • 1201 Answers
SOURCE: Burning smell,check engine light-misfire, rough idle 96 cavalier
Sounds like there is a blown piston, to be sure have a compression test done on that #2 cylinder, if the reading is low, then you'll know.
A friend of mine had a 95 that did simular things only a little more,
it started smoking, dash lights flickered, etc. Finally, he had to get rid of it, the piston rod went through the engine block.
Posted on Feb 02, 2010
2012 Kia Sorento 4cylinder / check engine light code 269 / had injectors cleaned by Pep Boys / light back on. Could it be the wire connector to the injector.
Your reference to Pep Boys says it all. Take your Kia to a real shop and have DTC P0269 verified with appropriate corrective action.
Mar 05, 2018 | Kia Sorento Cars & Trucks
I have a 2006 ford taurus that skips bad the fuel pump has been replaced 2 times n the compter
By "skips," I'm assuming that you mean it has a misfire.
Check all of the following:
  1. Fuel filter;
  2. Fuel pressure regulator:
  3. Spark plug wires;
  4. Spark plugs;
  5. Fuel injectors;
  6. Coil packs
  7. If there is a CHECK ENGINE light showing, have all codes read and correct all conditions.
  8. If the car sat for more than six months recently, if you live in an area where humidity is high, or if there is any chance of fuel contamination, manually drain ALL FUEL and replace with new. Use FUEL SYSTEM AND FUEL INJECTOR CLEANER every six months.
Jul 25, 2014 | 2006 Ford Taurus
Isuzu 3ltr turbo diesel no fuel to injectors
this is USA forum, and we dont have this car.
IT'S NOT A USA 2002 DIESEL trooper.
that and exact engine, size.
we have, 3 gas engines, 2.2L,3.2. and 3.5L
here. only and books that cover only those 3 engines.
so if a diesel dies.
what>?
check fuses.
scan it.
check filters
try test fuel to see if it runs on test fuel
test the glow plugs yet,?
if pump pressure is dead,?
check, power to the pump yet? (fuses are first)
there are 4,.6 and 8cyl. diesels by Isuzu.,
which is it>
they have names.
7 diffr. B engines, 3,xxxx liters.
and
5 diffr. 4Jxx series engines.
my guess is the engine is.
3.0 L 4JX1 TD I4
3.1 L 4JG2 TD I4
wiki says.
European and Asian buyers could opt for the diesel engine option of the 4JG2 3.1-liter (later superseded by the more problematic 4JX1 3.0-liter of 159 PS or 117 kW)
4jg2 is indirect injected
4jX1 is direct.
apples and orange diffr.! injection classes. '
learn what's under that hood, then fix it?
what country
what engine, real names, not 3L vague-ness. please.
Apr 21, 2014 | 2002 Isuzu Trooper
Suzuki fuel problems
It can be low fuel pressure or clogged fuel filter or worn out fuel pump.
Check the help links mentioned below to troubleshoot the isue:----
FUEL SYSTEM PROBLEM
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
How to Replace a Fuel Injector
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-injector.html
How to Replace a Fuel Pressure Regulator?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-pressure-regulator.html
How to Replace a Fuel Pump?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-pump.html
HOW TO CLEAN A FUEL SYSTEM
http://schematicsdiagram.blogspot.com/2011/07/how-to-clean-fuel-system.html
HOW TO REPLACE A FUEL TANK
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-tank.html
HOW TO REPLACE A FUEL TANK CAP
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-tank-cap.html
HOW TO REPLACE A FUEL PUMP ASSEMBLY
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-pump-assembly.html
Jaguar Fuel Pump
http://schematicsdiagram.blogspot.in/2012/07/jaguar-fuel-pump.html
Fuel leaks from fuel pulsation dampener on Toyota Corolla?
http://repairhelpcenter.blogspot.com/2012/01/fuel-leaks-from-fuel-pulsation-dampener.html
Car will not allow to put fuel?
http://repairhelpcenter.blogspot.com/2012/01/car-will-not-allow-to-put-fuel.html
Adding performance chip to increase Fuel mileage MPG?
http://technoanswers.blogspot.com/2012/01/adding-performance-chip-to-increase.html
How to test Electric fuel pump on GMC sonoma?
http://technoanswers.blogspot.com/2012/01/how-to-test-electric-fuel-pump-on-gmc.html
Fuel gauge drops to Empty?
http://technoanswers.blogspot.com/2012/01/fuel-gauge-drops-to-empty.html
Fuel pump not working on 1991 Ford Ranger?
http://technoanswers.blogspot.in/2012/01/fuel-pump-not-working-on-1991-ford.html
Fuel pump has no power on 2002 ford 350 7.3 diesel?
http://technoanswers.blogspot.in/2012/01/fuel-pump-has-no-power-on-2002-ford-350.html
Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down?
http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
Ford Fuel pump Relay and fuse location diagram?
http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-relay-and-fuse-location.html
Ford inside fuse box diagram showing fuel pump relay?
http://technoanswers.blogspot.in/2012/02/ford-inside-fuse-box-diagram-showing.html
Ford fuel pump fuse layout diagram?
http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-fuse-layout-diagram.html
How to lower fuel pressure on Toyota Hilux?
http://schematicsdiagram.blogspot.in/2012/02/how-to-lower-fuel-pressure-on-toyota.html
Fuel pump not running?
http://schematicsdiagram.blogspot.in/2012/02/fuel-pump-not-running.html
How to replace fuel filter on BMW 525i?
http://schematicsdiagram.blogspot.in/2012/03/how-to-replace-fuel-filter-on-bmw-525i.html
How to change fuel injector on 2005 gmc envoy?
http://schematicsdiagram.blogspot.in/2012/03/how-to-change-fuel-injector-on-2005-gmc.html
Time to replace Fuel pump on 1998 Ford Explorer?
http://schematicsdiagram.blogspot.com/2011/12/time-to-replace-fuel-pump-on-1998-ford.html
Emergency fuel shut switch on Ford car?
http://schematicsdiagram.blogspot.com/2011/12/emergency-fuel-shut-switch-on-ford-car.html
How to jump fuel pump On Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/how-to-jump-fuel-pump-on-chevrolet.html
How to Increase gas mileage on 2011 2500HD Duramax 6.6?
http://schematicsdiagram.blogspot.com/2011/12/how-to-increase-gas-mileage-on-2011.html
How to Test and Replace Fuel Injectors on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-fuel-injectors.html
How to replace Fuel Tank Assembly?
http://vwrepairhelp.blogspot.com/2011/11/how-to-replace-fuel-tank-assembly.html
FUEL LINES AND FITTINGS on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/fuel-lines-and-fittings-on-acura-car.html
Replacing Fuel Charging Assembly on Car?
http://vwrepairhelp.blogspot.com/2011/11/replacing-fuel-charging-assembly-on-car.html
How to replace Fuel Pressure Regulator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-fuel-pressure-regulator.html
How to test Fuel Pressure and replace Fuel Pump on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-fuel-pressure-and-replace.html
Car will not take fuel into the fuel tank?
http://repairhelpcenter.blogspot.com/2012/01/car-will-not-take-fuel-into-fuel-tank.html
PGM-FI Main Relay on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/pgm-fi-main-relay-on-acura-car-models.html
2003 Pontiac Grand Prix: Erratic Fuel Gauge?
http://technoanswers.blogspot.in/2012/06/2003-pontiac-grand-prix-erratic-fuel.html
Fuel Running Lean
http://technoanswers.blogspot.com/2012/10/fuel-running-lean.html
ECM misfueling Engine?
http://technoanswers.blogspot.in/2012/03/ecm-misfueling-engine.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
How to relieve fuel pressure?
http://technoanswers.blogspot.com/2012/01/how-to-relieve-fuel-pressure.html
Refueling problem?
http://repairhelpcenter.blogspot.com/2012/01/refueling-problem.html
Toyota Tercel consuming more fuel?
http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html
How to maximize fuel economy on your vehicle?
http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html
Fuel gauge jumps from empty to full?
http://schematicsdiagram.blogspot.com/2011/12/fuel-gauge-jumps-from-empty-to-full.html
Gas gauge stuck on empty on 2002 Mercedes Benz 240c?
http://repairhelpcenter.blogspot.in/2012/02/gas-gauge-stuck-on-empty-on-2002.html
No power to the control side of the fuel pump relay?
http://schematicsdiagram.blogspot.com/2011/12/no-power-to-control-side-of-fuel-pump.html
Fuel Injection Problem And RPM suddenly increases
http://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
VAN emits whitish bluish smoke and bad fuel smell from exhaust
http://schematicsdiagram.blogspot.com/2011/12/van-emits-whitish-bluish-smoke-and-bad.html
Ford runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Chevy Fuel pressure Reliving Procedure
http://schematicsdiagram.blogspot.com/2012/11/chevy-fuel-pressure.html
Fuel pressure and spark is good but ford escort will not start?
http://technoanswers.blogspot.in/2012/01/fuel-pressure-and-spark-is-good-but.html
2005 Lexus SC430: Fuel Door will not open?
http://howtobyme.blogspot.in/2012/05/2005-lexus-sc430-fuel-door-will-not.html
2005 Lexus SC430: Fuel Door, Dome light and Fuel Gauge Fuse Location?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
Toyota Fuel line diagram
http://technoanswers.blogspot.com/2012/12/toyota-fuel-line-diagram.html
These will help.
Thanks.
Dec 09, 2012 | Suzuki Cars & Trucks
I have a 97 dodge Dakota v6 manual, lately when I press the gas I hear a clicking noise and it gets louder the more I accelerate. Also when I put it in neutral to slow down for a stop sign or red light it...
The fuel pressure line is getting blocked.Get the fuel pressure checked.
Fuel Running Lean
Refueling problem?
2003 Toyota Camry: Fuel not flowing to engine?
http://whatisbyme.blogspot.in/2012/05/2003-toyota-camry-fuel-not-flowing-to.html
ALSO FOR,
CAR NO START PROBLEMS:-----
It can be the issue with weak battery or faulty battery or if battery is ok,then its faulty starter causing the issue.
From start to end troubleshooting these problem i suggest you to click the link below and follow its procedure:-----
What to Do When Car Turns Over But Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start? http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start? http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start? http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start? http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html ------------- Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
Derrick Shultz and Lidia Harper - Indian spammers?i get in and the check engine light came on and was flashing and it was idleing (shuttering) what could this be?
To confirm the exact fault,the error code stored in engine computer module has to be retrieved.
But as why check engine light came up,for that issue there are few help link with solutions to correct the issue.========
Click the link below:---
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
------------How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
------------Check Engine Light Reset Procedure? http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
------------- Check Engine Light ON? http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
----------- Intermittent Check Engine Light? http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
---------- Service engine soon Light Turned OFF after Jump Start? http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
---------- 2005 Chevy Impala: Service Vehicle Soon Warning Light? http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
--------- Malfunction Indicator Light ON http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
--------- Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving? http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
----------1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash? http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
--------Check engine light with codes P2195 and P2197? http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
---------Car Runs Fine But Check Engine light is ON? http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
----------After replacing throttle body the Check engine light starts blinking? http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
---------OBD Code is cleared but check engine light will not RESET? http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
--------These will help.Thanks.
Nov 22, 2012 | 2002 Jeep Grand Cherokee
Do not know how to check injectors on my 1990 lumina 3.1l
For engine misfiring problem check the help links mentioned below. Click the link below to go through the troubleshooting procedure :---- No pulse to injectors? http://technoanswers.blogspot.com/2012/01/no-pulse-to-injectors.html
---------How to Test and Replace Fuel Injectors? http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-fuel-injectors.html
Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Engine Misfire codes for car?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Engine Misfire codes?
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
This will help.
Thanks.
Feb 12, 2012 | 1990 Chevrolet Lumina
Why check engine bulb indicates
There is error code stored in your cars computer.It has to be scanned to retrieve the codes stored in it.I suggest you to click the help links shown below :----Check Engine Light On car? http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
--------------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
------------After replacing throttle body the Check engine light starts blinking? http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
-------------Check engine light with codes P2195 and P2197? http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
------------Car jerks while going uphill and Check engine light is ON? http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
-----------Vehicle smog test failed Due to NO MIL/check engine light? http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
-----------This will help.Thanks.
Feb 07, 2012 | Cars & Trucks
Chevrolet 2012 Chevrolet Sonic Logo
151 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Glenn Smart
Glenn Smart
Vernon Taylor
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
