This could be the result of pitch adjustments gone awry. Also, you may have both the 45 and 33 1/3 buttons pushed down which cause it run at 78. Here are a few trouble shooting tips and you can find the full manual for the TT at the link posted below:
Record sounds too fast or too slow.
1.) Turntable is set for wrong speed. Make proper speed
selection for record type being played with platter speed
buttons.
2.) Variable pitch is engaged. Depress quartz button or
return pitch adjust slider to center detent position to
engage quartz lock.
Moving pitch adjust slider produces no effect.
If the LED next to the pitch adjust slider center detent
position remains green when the slider is moved, quartz lock is
engaged. Depress the quartz button to disengage the quartz
lock and activate variable pitch. The LED should turn RED
I'm finding that you can buy Audi TT turbo charger kits if you'd like for your Audi TT to be turbo charged. ----------------------------------------------------------------------- Renault car key
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video. Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Possible that there are errors in the DVD or if there is a disc within the DVD while the TV is watched , maybe it is trying to read and so makes the sound. Now is the DVD is not read and played it is possible that the optical head is faulty.
Try to do a head cleaning use a head cleaner or try with a cotton bud - to be done very gently on the lens eye.
ESP means Electronic Stability Program.When piloting an Audi TT if you enter a corner too fast for road conditions (wet or snow or mud) and suddenly let off the gas to slow yourself down (which is what most people do) you will experince oversteer. This simply means the back end of the car will slid out and point the car sharply into the corner as the front end trys to swap places with the rear end. ESP will try to save you by electronically applying individual brakes to individual wheels to get the TT pointing the right way.-----------This will help.Thanks.Helpmech.
I strongly suspect you have air in the brake lines. Bleed the brakes and go from there. Of course there may be other issues, but this is where I would start.
Make sure the driver for the notebook from the manufacturers website is installed, and not the video driver from Microsoft's Windows Update. After that, update Java, Adobe Flash and Adobe Shockwave. Finally, check for updates for DirectX (version 9.0C). Post back your results, please.
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
It's a Furguson Turntable with encoding pt100 (I think!!)
