Computers & Internet Logo
M
Mike Rabel Posted on Nov 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connect to ipad and laptop
Ipad not working because my netgear is not connecting
Ajay Kumar
Level 2:
Habit-Forming:
New Friend:
  • Expert 49 Answers
  • Posted on Dec 10, 2016
Ajay Kumar
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
49
Questions
20
Helped
10776
Points
103
Can you plz attach the image file to your question
Windows laptop says netgear security code is wrong
http:.//routerlogin.net user name : admin
password: password, look for wireless setting, next , look for security option choose wpa-psk, choose passphrase.
this will let you choose more simple pass key
Netgear n600
Does your IPAD or your computer show the Netgear88 as an available connection. If you are using windows 7 you should be able to look at your "network and sharing" page. Then click on "connect to a network" (2nd one down). When click on that another screen should open up showing which band your computer is connected to. It should also show the OTHER band as well. It will also show the signal strength for both the Netgear88 channel and the Netgear88 G channel. If that information is there and the signals are good then the problem is in your IPAD. You may need to check to see if it needs to be updated as well.
No internet access netgear router
It may be the device you are trying to connect. shut down everything, unplug , remove batteries, plug in the ISP model, allow the self test, plug in the wireless device, allow it to self test, plug in, reboot the device, laptop, desktop, ipad, phone, whatever. You say you can connect using a Ethernet Cable? Just no connection wirelessly?
I purchased a Netgear Universal Wifi Extender for my ipad, i've set it on on the ipad and it says its connected and evreything and the little correction mark comes up on the ipad showing connected. the...
Extender means it extends the existing Wifi or network. So the iPad now connects fine to the extender, but the extender needs to connect to the existing network either via Wifi or cable. You need to open from the iPad the admin page of the extender and find the connection details there to your existing network.
Dell XPS M1530 laptop can't access Internet with Netgear router DGN 1000.
Have you opened Internet Options, Connections tab, Lan settings, Check Auto Detect. OR release and renew your IP address : http://www.wikihow.com/Refresh-Your-IP-Address-on-a-Windows-Computer Is your wireless adapter enabled? Drivers up-to-date? in working order? Have you run the diagnose in Manage Network Connections. What is your Anti Virus? Try connecting with it disabled?
Netgear Wireless router WNR1000 connect ipad
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
Netgear cant connect to ipad
I think you should check the wireless settings of the router netgear router and the iPad .
Do you have any other wireless computer or device in the network?
Can you connect any other computer or device to the wireless network?
If your wireless network is secured then make sure that you have the correct network key.
See the links below:
Netgear router setup
How to connect iPad to Wireless network
I have a Netgear router Model # WGR614 v7. The new Ipad cannot connect unless I tell it to forget that netwok, then reset network settings. I then unplug the router, leave it a minute or two & then...
What version of iOS is the iPad running? Try updating the iPad to the latest version of iOS (4.3.1) and see if the wireless situation is better.
To update the iOS, just plug the iPad into you computer and look in iTunes to see if an update is available for the iPad.
My wireless router isnt working. I have a NETGEAR Wireless-n 300 Router with the label WRN2000. Is this a strong router and can I get a stronger one that produces the capability to use more wireless...
That is a good router.
Is your wireless device (iPad? laptop? notebook?) using a Wireless-N adapter?
If not, all you get is the much-slower "Wireless-G" speed.
Measure, measure, measure.
If you use an Ethernet cable to connect from your computer to your router, do you get a much-faster connection?
How far (and how many walls) between your router and your computer?
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
