Question about Sylvania Televison & Video
Silvanya LC321SS9 B standby led... wont turn on
Hi a have a Sylvania LC321SS9 B. the problem is that wen a press the power boton the green led power flash one time and goes on standby. tv wont turn on at all
Posted by Alienware X51 on
3answers
Sylvania LC321SS9 B 32 LCD, won't turn on
Has this unit been near a lightning storm lately?/ Not that this is your issue. But I've had a T,V. do the same thing to me. I took it apart hoping it would be a blown fuse. But i was told a capacitor was blown out
2answers
Won't turn on led flashes green 8 time
Sounds stupid but I've had this issue with 2 different brand TV's and I unplug them for 5-10 minutes and then they are fine. I just had this happen just a week ago with a TV again.
1helpful
2answers
MY Sylvania LC321ss9 TV just shut off today!
It means your power supply went out. I had a sony with the same symptons and it cost 140 to fix it.
1helpful
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
1helpful
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
11helpful
WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
Unable to program my Comcast Remote to a Sylvania LC321SS9
Are you helping me or is it that I pay you for help provided free by someone else.
10helpful
4answers
Sylvania LC321SS9 remote code
I have the sylvania LC321SS9 tv and a atlas dvr1056 remote code 1864 works great with all functions!
Rca remote, codes don't work for sylvania tv
Trata con esto.
Presiona el boton Code search y mantanlo asi hasta que el led se quede encendido suelta y presiona el boton TV despues vas a presionar y soltar el boton Power hasta que el televisor se apague despues presionas el boton enter y el codigo queda almacenado.
El Tv tiene que encenderse primero manualmente.
Televison & Video Logo
Top Sylvania Televison & Video Experts
 Francisco Mauricio...
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
