Question about Thomson Audio Players & Recorders
Thomson wireless Headphones. The red input/power light is not indicating on the base unit where you lodge the headphones. The green charging light is lit up. How can I resolve.
Posted by Raymond Stephenson on
Michael Ryan
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Murdo's tip to trim off the cover of the AA battery base to expose a few mm of metal is spot on. Replacement rechargeable batteries for my Thomson wireless headphones did not charge, no green light, utterly frustrating, till I read Murdho's suggestion. Thanks for that
Posted on Oct 02, 2018
5 Related Answers
SOURCE: fm wireless headphone batteries not charging
you need to replcae the charging pin of your head phone, it is having loose connection............
Posted on Jun 20, 2009
Anonymous
SOURCE: Headphones has red light
Hello, I believe I just figured out the solution to this problem. I was experiencing the same thing, and as I was just showing my friend the problem I noticed that the green light came on after I turned on the music on my computer.
So, after removing the headphones from the base, the green light will come on only if there is sound playing from the computer (It takes a few seconds to turn on). It seems like they should have mentioned this somewhere in the manual...
Posted on Dec 31, 2007
Anonymous
SOURCE: logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Posted on Mar 19, 2008
JL Thompson
  • 155 Answers
SOURCE: No green On/Off light. Charge light is red. I hear only static.
Two things.. Check the batteries..
Also.. since these headphones have to have a signal sent to them to activate transmission (green light simply indicates they are receiving a signal) it can take a few moments after the signal begins to activate them.
I would hazard a guess that when you unplug the cables and then plug them back in.. the feedback that generates activates the base much the same as a regular audio signal would
Finally.. make sure the source is a fixed output.. if not.. and its variable..you will have to increase the output or volume to activate the base..
Posted on Apr 24, 2009
Anonymous
SOURCE: Batteries for Philips wireless headphones
Actually, look at the Philips SBC HB550S battery, the black label on battery isn't going to the end of the battery's "-" side, there's few millimetres of solid metal. Look at other, ordinary rechargeable battery, for ex duracell's. This other battery has label all over battery (from "+" to "-"). So only thing you have to do to make any batteries work with you have to cut and remove this label from battery you want to use from the "-" side of the battery, about 1-2 cm, like philips one has. It's because these headphones have this extra clip in battery sockets, philips wants us, customers, to buy those extra-expensive batteries. That's as simple as it is! Hope it helps you, it definitely helped me.
Posted on May 04, 2009
How do I know when my kocaso wireless headphones are charged
If the light is red during charging it should turn blue,green,or white. This is how most indicator lights work.
Jun 07, 2016 | Audio Players & Recorders
The green charging light is not coming on when the headset is placed on the charging station
Wait to see if it gets a charge on the port. If the headphones don't work, call customer service for troubleshooting relief.
Apr 06, 2015 | Thomson WHP3001BK WIRELESS HEADPHONES
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Dec 30, 2014 | Audio Players & Recorders
The operating instructions say that after 16 hours the red power/charge indicator light would go out, indicating the batteries are fully charged. After 3 days the red light on my unit is still on. The...
I have the MDR-RF970R but I bet the battery is the same. If you have had the headphone for seceral years then I bet you are right, the battery is going. You might try using them till the battery dies and then recharge. This is called deep cycle and may time it will extend the life of rechargables.
If the headphones are new, then just check and make sure that they going all the way into the charge slot.
I will say it is not common for me to see the light off, but I use the headphones all the time.
Good luck.
Apr 30, 2010 | Sony MDR-RF970RK Headphones
No sound from RS130 headphones
I'm having the same problem with the RS140. Only a few weeks old, and no sound at all coming out (not even the beeps). Have replaced batteries and tried a different audio source. Base station lights are on and indicating it is receiving an audio signal, but nothing is going go the headphones.
Jun 25, 2009 | Sennheiser RS130 Wireless Headset
Jan 26, 2009 | Sennheiser RS 120 Consumer Headphones
PHILIPS HEADPHONES SBC hc 8440
Hi there!
OK I know it is little late to response but if someone will google it, might find the solution, they are still selling it though. I just got my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small power in it, however you have to charge it. So connect the small charging cable into the base unit and the headset and make sure the switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity supply. Connect the audio connector from the base to the e.g. TV, PC, DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have two of the same wireless sets. So if on the base is set to # 1 the headset needs to be also on # 1. Then if you have second headset choose channel # 2 on the base and also on the headset # 2, so they are not crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
Hope it was helpful.
Michal Bohucky
Jun 01, 2008 | Audio Players & Recorders
Top Thomson Audio Players & Recorders Experts
Jean Sintulaire
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
