Question about Electric Health & Beauty
I charging my electric wheelchair a DL 5.2i. when is changing completed?
Posted by Mack Petty on
wcdoc1953
  • 280 Answers
On this controller there is a 6 light LED display above the battery icon which is below the horn button. Turn on the power chair with the 1/0 button and the LED display will light up. The lights are red on the left, yellow in the middle and green to the right. If all 6 lights are lit the chair is fully charged. Hope this helps.
Posted on Nov 20, 2016
1 Related Answer
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
How do i recharge a dead battery for my quantum motorized wheelchair?
First ensure the battery is completely discharged by using a voltmeter or other suitable method.
If the battery really is dead it should be charged with a suitable known good battery charger for the required time, allowed to stand a few hours and then tested by putting it into use or employing a suitable method of testing.
All disability scooters and electric wheelchairs arrive with a dedicated battery charger which should be used if possible, though these sometimes fail and need replacing. In that case other methods of charging can be employed but purely on a temporary basis as there are safety concerns with battery charging.
If charging the battery does not work, it might need replacing and/or there might be a fault with the wheelchair.
Feb 25, 2017 | Quantum Health & Beauty
How long does it take to fully charge a wheelchair batteries
If the batteries were discharged completely, the battery charger isn't strong enough to start the charging process. Take the batteries out and charge each one separately with an automotive type battery charger that is NOT automatic. This may take a day to recover this way. When the battery shows over 10 volts with a dc voltmeter you can re install them in the chair to complete the charge with the 24 volt charger. If the batteries have any amount of age past 2 years, it's time for new batteries.
Sep 26, 2015 | Pride Mobility Products Used Jazzy...
Why is my merits DL 5.2i stuck in low speed ?
You may have a thermal rollback issue. Try charging the chair overnight and leave the controller on while charging. This will give the control module/joystick time to reset themselves. Thermal rollback happens when a certain temperature in the motors is reached. The system shuts itself down to protect from damage.
Apr 26, 2014 | Select Jazzy Used Electric Wheelchair
I have a pride ultrax and I have a full charge but no power
Hello,is the charger working properly & has the battery also been tested?.Sometimes the obvious can be the fault,but many people overlook it.I hope this has helped.
Jan 06, 2014 | Electric Mobility Mobility Electric Power...
Merits wheelchair 2 center flashing lights when turned on
Flash Code 2 indicates that the voltage is too high or too low. Check batteries and cable connections. Charge the batteries. If this fault occurs during battery charging, the charger is defective or not adjusted correctly. Empty batteries will charge. Dead batteries will not normally charge.
Feb 26, 2013 | Electric Mobility 24 " Seat Merits Heavy...
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
Jul 15, 2010 | Health & Beauty
Battery runs out in less than 60 min, used to go for hours.
Hi. With batteries it is very important to recharge them after each use, overnight. I have seen batteries last 7 years in a mobility scooter, because the batteries were charged properly. Batteries store electrical energy by means of a cemical reaction, and if left in a discharged condition for too long, damage is done to the internal plates of the battery.
Batteries are designed to do so many charge cycles.
If a battery is run down to 75% or more, you will not get many cycles out of it. If you only run it down by 25%, you will get 100's of charge cycles out of it.
I would say that you will need to purchase new batteries for it.
When changing the batteries, change one completely first, and then the other. This way you will be less likely to mix up the wires.
Red is positive, and black is negative.
Good luck. Neil.
May 30, 2010 | Quickie Wheelchairs Quickie Wheelchair 18"...
How can you tell when the battery is charging?
Your indication that the internal battery on the joystick is charging IS the red light, which in some configurations
may turn to different colors as charging progressses, but if you note no color change, and/or if when you disconnect the joystick from the power, the light either does not stay on or the stick does not operate independantly of the power source, then the internal battery is defective, has exceeded the number of recharges
cycles and/or is fried.
Buy a new set of batteries for all sticks at the same time and play on.
Apr 17, 2009 | Electric Jazzy 1115 Power Wheelchair
Health & Beauty Logo
594 people viewed this question
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
barrybam
jws1013
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
