Question about Yard Machines Garden
How to replace the starting rope for Yard Machines Y125 10-Inch garden tiller 25cc 2 Stroke Gas Powered
Posted by sadik Malushaj on
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Posted on Mar 21, 2009
Anonymous
SOURCE: tiller doesn't run
There are two pictures of the position of the fuel lines at this site, http://www.hobbytalk.com/bbs1/showthread.php?t=147204. You will have to register in order to get the pictures. The registration is free. Hope this helps.
Don
Posted on Apr 13, 2009
Anonymous
SOURCE: both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
[email protected]
Posted on Apr 27, 2009
Anonymous
  • 155 Answers
SOURCE: change the blade
try this site its called pats small engines just look up your model and it will show you a diagram
Posted on Jul 26, 2009
Anonymous
SOURCE: Sears Gas powered blower 25cc/1.5 Cu. in 2 cycle
I have craftsman 25cc 2-cycle blower-It wont turn over-I put new spark plug and cleaned filter. It dosen"t seem to be getting any gas. How would I know if its the gas filter and how do I put new one on? thanks,mh
Posted on Feb 18, 2010
How do you replace the pull start rope?
Remove retaning bolts on the housing make sure all the old rope is ggonerewind the housing useing a screwdriver to hold it in place thread the new rope through the housing release screwdriver and reattach to motor.
Apr 18, 2016 | Yard Machines 121R 31cc 2-Cycle Gas...
How do i repair pull string on my yard machine 135202 tiller
remove starter
get new rope
wind spring DONT LET GO UNTIL DONE
feed in new rope , tie knot in rope, replace handle ,tie knot in that end. NOW YOU CAN LET ROPE RETURN IN SLOWLY
May 10, 2014 | Mtd Products Yard Machines 158CC Tiller
Weedeater fb25 runs too lean
Because of Federal Emission standards all newer 2 stroke engines are tuned extremely lean. You can have it adjusted and richen the mixture.
Nov 01, 2013 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
No spark on Weed Eater FB25 25cc Gas Blower
Test the kill switch first, disconnect the kill switch and see if you have spark. Then the kill switch is not working or is grounding out. If not, the problem could be the ignition module.
Mar 16, 2013 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Recoil starting mechanism will not recoil starting rope. How do I fix?
You could fix it ... I suggest you replace the recoil mechanism. Find a replacement at your Yard and Garden store that sells your brand of engine.
Feb 14, 2011 | Yard Machines Garden
How do you start a 2 stroke Mantis? I lost the book. Will
first, push the primer bulb a few times to get fuel circulated and air out of the carb. Turn on the switch, put the choke on full. Pull the rope until you hear it fire. Then put it on half choke. Pull the rope; it should fire within a few pulls, and should run. Take the choke the rest of the way off once it's running well. This is a standard starting procedure that works well for every kind of 2-stroke engine used in the garden.
Mar 28, 2010 | Mantis 2-Cycle Tiller
On my tecumseh tiller the rope broke and the setup has rivets instead of screws is there another way to get it off without removing the rivets?
I'm guessing you have a 3.5 or 4HP 4 stroke with the recoil built into the top of the housing? If so, just remove the entire blower housing. It's only 4 bolts. You can then disassemble the recoil assembly to replace the rope.
Mar 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Garden Logo
165 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
john h
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
