Question about Mitsubishi WS-55805 55" Rear Projection Television
Hooking uverse to Mitsubishi ws55805 - Mitsubishi WS-55805 55" Rear Projection Television
Posted by Page carwile on
At&T Uverse suggested that my HDMI ports on my tv were not working. I this possible They hooked it up by componets settings. The tv is about 5 years old
I doubt it. Try hooking up a component (DVD, Xbox) to one of the suspected bad ports. Go through your source settings in your menu or on your remote and see if they work.
Mitsubishi tv customer service
i have a blinking green light and then the red lamp light comes on and stays. no picture no sound
I have a mitsubishi wd52 52528 connected to uverse.....i cannot get hd for some reason, the sbt says it is dispaying 1080i but the tv says 480i ......help????
Make sure you have it connected to the correct input---one other thing if you have not tried it unplug set and HD box from power for a short time and plug them back
The set has a soft and hard reset, the soft with the original remote is Menu, 1,2,3 enter.
I have a mitsubishi ws 55315 and i need to program my remote to the att uverse motorola cable box.
hi i have a couple of codes here for your mitsubishi tv just try them 0005 0151 0051 0004 0009 0254 0022 0141 0180. hope this would help! goodluck!
I need a code for my mitsubishi wd60735 for the uverse remote
these codes are top secret,not given to the public.call a tech.
Hdtv
hi! might be best to call Uverse so that they could guide you thru setting the right aspect ratio for your TV. hope this helps!!! goodluck!!!
Ws55805 convergence circuit
Resistirs are designed to protect the circuits on the PCB. This is designed to allow a much cheaper part to burnout before the more expensive circuitry burns.
2answers
Mitsubishi WS-55805 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
 Grubhead
Grubhead
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
