First thing I would do is try a different DVD to see if the problem persists. Otherwise, this device is equipped with integrated speakers, meaning it is unlikely that you will be able to replace them. You may be in the market for a new Audiovox, unfortunately; but before you scrap it I suggest taking it to a local electronic repair store near you.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
1) test the adapter and repair or replace 2) test the power supply inside for open or short from some component, such <.diode, capacitor, resitor. 3) test the batteries and replace if necessary use the same kind all alkaline . God bless you
Hello Enter the Menu screen, select, preference, select default, and OK. If the problem is with password forgot, the default passord of this unit is [ 3308]. Enter this password on the first screen. Sometimes the unit won't accept this passord for the first time to cheat you, enter this pasword again. After that, you can enter your own passord. OK.
have you tried playing the dvd while it's charging? it might be that the battery is not holding enough charge tu run the dvd mechanism eaven if the green light shows the charge is complete.
i have an AUDIOVOX VERIZON POCKET PC and serusosly I cant turn on the phone i put it on charge the green light flashes but i cant even power the whole phone on is ther anyone that can help me thanks
