Question about Humminbird Sport & Outdoor - Others
? Does the Humminbird Helix5 sonar works like GPS ?
Posted by Mario Medina on
1 Related Answer
Anonymous
SOURCE: I need a users manual for a Humminbird 3
I have resolved the problem thankyou.
Posted on May 19, 2009
Will power up, but won't advance to menu
May require a software update.
register your unit at OnixSeries (this is a link to humminbird)
On your "My humminbird" page you will find free software updates for your particular unit.
download the latest update to an SD card and follow the instructions for the installation process.
Apr 20, 2015 | Humminbird 581I Hd Di Sonar/Gps Combo
Works on down scan but not on sonar
Hummingbird systems have the ability to turn off pages so they will not be displayed. On your main menu look for the "views" tab. Scroll down to the sonar view page and see if it shows visible or hidden by that page. If it says hidden, select visible and you should be all set.
Oct 01, 2014 | Humminbird 1158c Di Fishfinder With...
Why does my fish finder sieze up when i start my boat?
it seizes up because their is a very hi draw on your battery when the motor is turning over, the starter draws so much power from the battery that it drops the voltage down below what the depth finder needs
Aug 11, 2014 | Humminbird 597 Ci Hd Combo Sonar/Gps
When i power it on the screen just shows loading and never boots up
I don't have the same model but the same issue before the cable from the sonar was frade some and so it wasn't sending a good signal to the box so it just said loading I had to replace the sonar and then it worked fine
Sep 23, 2013 | Humminbird 161 Gps Fish Finder Combo
My Humminbird 788 ci screen clutters up and gives crazy depth readings when the trolling motor (mk terrpva80# w/ ipilot and built in td w/mkr-us2-8 cable) is set on mid to high speed settings. It does...
One thing you might try is restoring the defaults in your unit. One other thing is go into the menu under the sonar tab and adjust your Noise Filter. You may have some type of interference going on. You can call our customer service department and they will trouble shoot it for you. Our number is 800-633-1468.
Joby from Humminbird.
Jan 01, 2011 | Humminbird 787c2 Combo GPS Receiver
Humminbird Matrix 12 sonar/gps problems
Make sure the 'North Up' is set to 'True' in the settings.
Best of luck
Mike
May 03, 2009 | Hummingbird Humminbird 1155C GPS Receiver
Need a manual
Humminbird - Support Your product is listed. However, when you click to download the manual, the page is not available. Fill in the question, for support.
Feb 16, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Sport & Outdoor - Others Logo
87 people viewed this question
Top Humminbird Sport & Outdoor - Others Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Humminbird Sport and Outdoor - Other Expert? Answer questions, earn points and help others
