SOURCE: How do I enter code into my blaupunkt radio/cassette?
HY ACORDING TO THE MANUAL YOU SHOULD TURN THE IGNITION ON SWITHCH THE RADIO OFF PRESS THE AS BUTTON WHILE YOU TURN THE RADIO ON,AFTER 5 SECONDS YOU SHOULD HER A BEEP AND ON DISPLAY YOU CAN SEE 10SAFE AFTER 5 MORE SECONDS YOU SHOULD BE ABLE TO ENTER YOUR CODE USING FIRST FOUR BUTTONS FOR 0-YOU PRESS ONCE AND SO ON WITH THE OTHER DIGITS.
SOURCE: Blaupunkt radio bp2770r4514872 cassette got code need to put in
I hope this helps.
copy and paste this link in to your web browser search window and click go.
www.davidsonelectronics.co.uk/code_entry.htm
SOURCE: code for c 90 blaupunkt miami cassette player
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
SOURCE: blaupunkt cassette deck
Also quote the MAKE of CAR it is fitted into.
SOURCE: blaupunkt miami C90 cassette player codes
