Televison & Video Logo
don vu Posted on Nov 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model dta800b1 auto scan up to 67% then stop - Televison & Video
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Nov 16, 2016
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986825
Points
237762
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
1helpful
Additional question. How the auto scan works. I presume that pushing autoscan button tuner automatically scan given band and stops on each tuned station.
When you push the auto scan button on a radio tuner, the tuner will automatically scan through the available frequencies (also known as a "band") and stop on any station that it finds. The radio will then display the frequency or channel of the station and allow you to listen to the broadcast. The process of auto scanning can vary depending on the specific model of radio tuner that you are using, but in general it is a quick and easy way to find all of the available stations in a particular band. Some radio tuners may also allow you to save the stations that you find during the auto scan process, so that you can easily access them in the future without having to rescan.
You mean the ic in the box or in the remote control. by the way I want to make it clear that when I started auto scan all channel , the process stop at around 67% on the screen of the tv.thanks again
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC at the main digital board, inside the TV. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
I have an rca converter box model number DTA800B1. I unpluggd it briefly and now don't have the code toprogram it
DirectTV remote model Rc64 will control the RCA model DTA8001B1 digital receiver. Set the remote's switch to unused AV1 or AV2 position, simultaneously press and hold mute and select buttons until indicator gives a double flash and immediately enter code number 00392 after which the indicator will double flash in acceptance. Works menu and it's navigation, channel up and down, and numerical keypad.
1helpful
I need to know how to access menu or run channel scan on rca dta 800b1l converter box without the remote
There is not a way, unless you get a universal remote, scan for the code to control the box, and then get into the menu.
Have an rca digital converter box model dta800b1 and a phillips universal remote can i program it so my box get the channels
Find the user guide for your universal remote and use the RCA cable tv/satellite codes, and one should work for your RCA DTA800B1 converter box. My Sharp Aquos remote liked the RCA satellite code.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
