Vacuums Logo
A
Anonymous Posted on Nov 16, 2016
Hoover duo vacuum cleaner electrical wiring diagram
5 Related Answers
Anonymous
  • 583 Answers
  • Posted on Mar 03, 2009
SOURCE: wiring diagram
How to Repair a VacuumCleaner
http://home.howstuffworks.com/how-to-repair-small-appliances8.htm
Anonymous
  • Posted on May 04, 2009
SOURCE: hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Anonymous
  • 98 Answers
  • Posted on May 08, 2009
SOURCE: Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
Alex
  • 97 Answers
  • Posted on Jul 19, 2009
SOURCE: Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Anonymous
  • 701 Answers
  • Posted on Nov 19, 2009
SOURCE: How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Hoover React won't stay in upright position. What needs to be replaced please?
The latch at the bottom of your vacuum cleaner. The problem is that 'React' seems to be a range of cleaners.
Google
make model (number) parts diagram
https://www.google.com/search?q=Hoover+React
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
I have hoover platnium collection vacuum the lights turn on but does not run
If you are electrical handy, check for wiring continunity to motor or the motor itself could be bad. Only do this safely.
I need an instruction manuel for hoover floormate
The manual can be downloaded here; scroll down to "Product Details":
http://www.amazon.com/Hoover-H3000-Floor-Hard-Floor-Cleaner/dp/B00005R19P
2helpful
My hoover steam vac will not dispense the water
I did use my cleaner for along time , started it up and no water would
pump.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
