Computers & Internet Logo
D
Della Murphy Posted on Nov 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is asking for an access code to an access point . What is that?
Terry Hair
Level 3:
  • Computers & ... Master 4,134 Answers
  • Posted on Nov 15, 2016
Terry Hair
Level 3:
Answers
4134
Questions
Helped
1091979
Points
16804
Wireless networks can be secure or unsecure. Anyone can connect to an unsecure site simply by searching for available sites and choosing an unsecure one to connect to. There are inherit risks associarted with unsecure sites and you should NEVER do any financial or highly personal transactions on an unsecure network. Secure networks require a password (access code) to complete connection. This code is provided by the owner/administrator of the network. If you are allowed to connect to such a network, you should already be aware of the code. Otherwise you are basically not invited to the party.
I have a net rca tablet. It works fine except it won't go on wifi. I did exactly what I was suppose to do, and it won't connect.
Hi
I presume that the tablet detects a Wi-Fi network,since you say it won't go on to it.
A couple of points here - firstly this tablet will not go onto mobile broadband as there is no mention of a SIM card capability in the manual, which can be obtained in pdf format here:
http://www.rcatablets.com/sites/default/files/RCT6203W46%20IB_English.pdf
OK - one point down, so now we are talking about wireless access points. If the tablet doesn't detect an access point, it obviously won't connect. If it can detect an access point, then you need the access code to join that particular network. When you tap on the access point SSID (identification), it should ask for a wireless key which you must enter in order to access the Wi-Fi network and get on line.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nokia 6300,plz can you open my gprs?
call you service provider and ask them to send you the internet settings then install the settings which they sent. then ask thme what is the access point name. when they say the access point name write in the following place settings -> connectivity-> packet data-> access point ->edit active access point . after writing in to it restart your phone then start using gprs. Have a nice day
My nintendo wii wont connect to the internet keep poping up code 51030 and asking for my ssid
Do you have a wireless access point? It needs the name of the access point.
While connnecting pc suit, one touch access asking access point, user name, pass word
Yes, it will always ask for this. To resolve,
You must know these 3 parameters. Go to your Nokia mobile:
Tools->Settings->Access points->Click you Network Operator name like (AT&T)
Note down: Access point name, Username
Put these in touch access, use password as 0000 or 1234
If the above doesnot work, kindly contact network operator for password for Internet settings on dial-up modem.
Hope this helps.
E reader ask wep code/wont access the web
Do you know the WEP code?
If not then you won't be able to connect.
Remember not all access points are free and open.
4helpful
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
2helpful
How to configure a D-link access point DWL-3200AP
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
3helpful
HOw to view my access points n73?
this can be possible becoz of 2 reasons
1. U dont have any access point defined. So do one thing .. call ur network operator and ask them to send u the settings for mms. now store these settings and see if u r able to open this menu
2. THere is a bug in the OS. u will have to format ur phone.. *#7370# code(12345 default)..this solution will definately work and if u dont want to waste time calling ur operator format ur phone but backup ur data before doing tht
Cannot get internet connection on wireless
Well you cant, as its not your own connection, unless you ask ther person for there WEP access code.
Hope this helps
How do I get a password code
you need to call linksys the number is usually on the router they ask a couple simple qeus and give you a number
Grand Canyon Tech
Grand Canyon Tech
