Question about Motorola Radio Communications
Motorola bpr40 no modulation
When transmitting there is carrier, channel guard but no mod. already changed mic element. any ideas?
Posted by Gene Congilaro on
Mike Charette
    Genius:
  • Motorola Master
  • 1,847 Answers
Check your final for correct voltage . Also your driver then your Integrated circuits' . If they are bad then replace them .
Posted on Dec 04, 2016
PC 78 elite, no modulation
Check tr 14 15 AND 16 AND DIODES D14 D13
Jun 10, 2013 | Uniden PC78ELITE 40-Channels Base CB Radio
I have a galaxy 73v that transmits on oe channel recieves on another
common problem bad solder joints in the vco circuit take it to a PROFESSIONAL
Aug 21, 2012 | Galaxy Radios DX-73V 40-Channels Base CB...
Have a 99v was talking one nite talking great turn it off then back on no modulation check and change mics.still no mod.what should i look for ?
Check the mic gain.
Make sure it is not in PA mode.
Make sure the mic jack in the radio doesn't have a broke or loose wire.
Those are a few things I can think of based on the information given. More information is needed if these will no solve the problem.
Does it turn on?
Does it key up?
If it keys up is there carrier?
How many watts is the carrier?
Are there any mods done to the radio?
Does it have a roger beep installed? What kind?
Does it have an echo board install? What kind?
Did you do the mod or some one else?
What is your SWR?
Is the display flashing when you key it?
Are the displays lit at all?
Did you disconnect the power cord after you turned it off, and reconnect it?
What channel are you keying up on.
Was/is the case off the radio when you tried it or were you working on it at the time of the failure?
What mics have you tried.
are you using talk back?
did you some one on another radio tell you they do not hear you, or are you going by no swing on the meter in the radio?
Could the meter be bad?
Jul 31, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Hi i have a midland 98 plus,i have been told that when i talk it have very low volume and people have to turn their set up to full volume to hear me. but the same mic on a different set works fine
Look at Radio Mods or Defcom mods. To clip modulation diode inside radio. Take to Cb shop to Peak&Tune. It may be wound to high in carrier but not audio. Buy you a "Power Mic" at Radio Shack or WWW.COPPERELECTRONICS.COM.
Apr 01, 2011 | Midland 40-Channel CB Radio CB Radio
How can i modify the midland 75-822 for more channels?
Modding your CB for more channels puts the radio into Ham bands which you need a license to transmit on, also modding a CB violates FCC part 95 rules and is therefor illegal to transmit with and the hams report most illegal transmitting on there band
Jan 30, 2011 | Midland 75-822 40-Channels Handheld CB...
Connect power mic to my superstar121 and transmit light comes on. Connect original mic and all works fine any ideas.
Hi,my name is John. Welcome to FixYa. Your power mic. needs to be wired the the radio. Thanks for choosing FixYa....John
Nov 16, 2010 | Superstar SS-121 120-Channels Base CB...
I have a Cobra 18 wx st. I am not able to transmit anything on it. I have checked the antenna cables and and all external connections. I receive all the wb just fine but the CB gives me nothing. I tried a...
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike. With the WX band working, the above may not apply.
See if you have a carrier...signal going out, but no modulation. Get your Tech to check the mike wiring/circuitry inside the radio, also.
Jul 06, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Powers up, recieves fine, breaksup on transmit Galaxy 949
Check the wiring on the mic plug sounds like you have a loose wire or one thats about to break off.Good luck.....Dan
Apr 01, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Superstar 3900
If you have a PA function on the radio does the mic put out audio, if it does this would rule out the mic
Aug 23, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Radio Communications Logo
145 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
