Televison & Video Logo
Bruce Morley Posted on Nov 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The cd player is not sensing the cd .i can hear it try to start but keeps on saying no disk
Andrew Pierce
Level 2:
Sergeant:
  • Expert 186 Answers
  • Posted on Nov 16, 2016
Andrew Pierce
Expert
Level 2:
Sergeant:
Answers
186
Questions
Helped
43756
Points
709
Try a different cd
try cleaning the cd
use an old cd and glue an eraser size piece of clean felt to it
make sure glue is dry and no hanging edges near felt
run cd with felt through player for five min to clean laser
try original cd still doesnt work open up and reset arm to
start position sometimes arm gets stuck.
replace cover try good cd again
still doesnt work maybe time to give up
2answers
I have lg DVD player and it says no disk when i insert the dvd it
MBB, First clean the CD/DVDs in plus manner. Up -down and right - left. And not in the usual circular as most of us try to clean them. Use a soft dry cloth.
10helpful
2answers
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
It keeps saying unknown disc,every time i put a disc in there every disc that i put in the player...it will not play it...it keeps saying Unknown-disc...including an audio-disc.
hi, try first to insert a clean up CD, and test your Cd or Dvd player with an original CD or Dvd, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
Sserpentio
6helpful
Dvd player wont read disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Dvd keeps reading no disc
It can be several reasons
1. Disk is upside down
2. Lens is durty. You will need to use CD/DVD cleaning disk for that
3. Disk is having diffrent region code or recorded in diffrent formate (for instance player playback disk recorded in NTSC, and you trying to playback disk in PAL formate)
4.Disk is recorded at higher speed (for instanse player markered X16, but disk is recorded at X24)
Good Luck
4answers
Dvd problem
Hello
You need to clean lazier in it. You need to open it.
Boss cd dvd player
Can you hear the drive spin? If you can, buy a cd cleaning kit and try. Sometime the laser len is dirty and the same message occur. Goodluck.
3answers
Disk error
can you hear the cd spin?
more times than not the laser is bad.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
