Question about Vulcan Heating & Cooling
SOURCE: Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Posted on Sep 24, 2007
SOURCE: Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Posted on Jan 13, 2009
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
SOURCE: Projector fails to turn on
check your lamp. if it has bulges, black spots or fogging, replace it. otherwise, its your power supply/ballast.
Posted on Dec 28, 2009
Dec 25, 2016 | LG 47 Inch LED TV 47LN5200 LN5200 Series...
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Jul 18, 2014 | Mitsubishi WD Televison & Video
Jan 18, 2013 | Vulcan Ovens
Nov 20, 2017 | Ovens
Dec 21, 2010 | Ruud Central System Air Conditioner
Apr 18, 2010 | Televison & Video
Jun 18, 2009 | LG RU-52SZ30 52" Rear Projection...
Dec 10, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
54 people viewed this question
