A sewing machine operator can often help themselves when their machine does not operate properly. Here are some simple instructions, which if properly used can save time and mechanics service calls. TROUBLE;UPPER THREAD KEEPS BREAKING; This could be trouble;================Do this; 1.Top tension to tight================loosen tension 1 turn 2.Machine improperly threaded=========check threading 3.Thread twisted on guide post========" 4.Thread twisted out of tension=======" 5.Take up spring bent or broken=======Check action of spring 6.Thread jumped off pull off finger===Check threading 7.Needle bent or burred===============new needle 8.Bad cone of thread==================try another cone TROUBLE;LOWER THREAD KEEPS BREAKING; 1.Bobbin tensionspring to tight=======Loosen tension slightly 2.Bobbin threaded wrong===============check threading 3.Bobbin wound to tight or uneven=====try new bobbin 4.lint or thread on bobbin case=======clean inside case 5.Lint or thread inside hook==========clean inside hook 6.Bobbin case nicked bent or burred===check/change case TROUBLE;MACHINE STARTED SKIPPING STITCHES; 1.Needle bent or burred===============change 2.Needle set in crooked===============Check 3.Thread jumped off take up spring====check threading 4.Thread jumped off pull off finger===check threading TROUBLE STITCHES SHOWING LOOPS; 1.Forming loops on top of cloth=======Tighten bobbin tension ======================================or loosen top tension. 2.forming loops on bottom of cloth====Tighten top tension 3.Bobbin placed in case incorrectly===remove and replace 4.Bobbin thread slipped from under====check threading of tension===============================bobbin case 5.Lint or thread in top tension=======clean between tension discs
