Question about Video Cameras
Myhpcamcorder reads code540-202 what does it mean
Posted by omar juarez on
What does no continuity mean in both sides of a fuse on a motorcycle mean
fuse is either good or bad, a visual inspection is a good tool. Continuity means that electricity flows through the wire, fuses will read the same independent of which probe is placed on each end no continuity = bad fuse. if using a dmm the reading is is 0 ohms or infinity ohms. if you are hold probes on fuse there will a high reading which is your body
Jun 01, 2018 | Motorcycles
Gamma/GT high mean I don't understand what this
I don't know how this got posted under 'Cars & Trucks', but I think you need to have a read of this page which may be of help to you.
A reading of more than 51 apparently. means it COULD be a problem. Read the page.
http://www.nlm.nih.gov/medlineplus/ency/article/003458.htm
Sep 15, 2014 | Cars & Trucks
Injector 4 in ford diesel
reading what does that mean.
1:your read this in a book.
2: or the DMM voltmeter reading measured, 12v (high or hot)> did you?
Nov 27, 2013 | 1996 Jeep Grand Cherokee
How do I test a stator?
Put a multi tester across the two wires from the stator. Set the tester to Ohms, the reading can be compared to the manufacturers stated values. The reading will look something like 3.5 or 4.57. If it reads 0.00 0r some other low value like 0.81 it probably means the stator is faulty, (0.00 means dead short, no reading or flashing digits mean no circuit).
Oct 13, 2013 | Garden
Engine Code Reads (rEAd)
When i see that on my scanner it means to hit the `enter' button and it will read the codes out for you.don-ohio
Oct 18, 2011 | 1999 Mercury Sable
My hard drive wont read it worked before dont know why
A disk-drive has several major components:
* the electronics circuit-board
* the power/data external connectors
* the motor that spins the disk-drive
* the read/write mechanism that moves above the recording surface
* the recording surfaces
No power means no "spin", and nothing happens.
Dead motor means no "spin", and nothing happens.
Dead electronics on the circuit-board means that nothing happens.
Damaged read/write mechanism.
Damaged recording surfaces.
Feb 26, 2011 | Hitachi Computers & Internet
In dash reading reads " Gearbox Fault". I don't
It means you have a problem in the shifter. Is it a five or six speed?
Jan 11, 2011 | 2003 Jaguar X-Type
DVD Rom dont`t writen DVD+RW
because ROM means read only memory and RW means read and write if u want"s to write DVD so change ur DVD-ROM into DVD+RW.
May 23, 2009 | Lite On Computers & Internet
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Video Cameras Logo
61 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
