Question about Refrigerators
My model AFI2538AEW fridge control panel is stuck and I cannot select anything on it.
Posted by Denise Daughtry on
schwaa44
    Master:
  • 252 Answers
Can you unplug and replug it back in to reset compter? It might be easier to go to your circuit breaker box, vs pulling fridge out, and turn off fridge from there. That will cause it to reset. Here is the manual for it.
http://kitchen.manualsonline.com/manuals/mfg/amana/afi2538aew.html
Posted on Nov 15, 2016
The control panel on my jenn air fridge model # jfc2089htb is not responding and I cannot adjust any setting. Fridge is stuck at 44f and freezer -1f
A simple reason could be the control panel is locked (child/safety lock) - look for a small lock symbol in the display.
Oct 30, 2016 | Refrigerators
How to program a amana modle # afi2538aew put in new card now trying to program it but i don't know what ll is or UR or LR can u help please
Hallo
First disconnected the card again wait 1min and reinserted it.
Now turn Fridge on and do not adjust anything within 24hours please. Wait for temperature to adjust the card is factory settings.
To turn Fridge off and on:
Press theFreezer + pad until "off" is displayed and press the - pad on the fridge or freezer controls to turn refrigerator on.
Hope this was helpful can you please send me a picture of what the controller display message please.
Regards
Jun 08, 2016 | Amana Refrigerators
My Maytag MTB2156DEB fridge died. Electricity is on, lights are on but nobody home, I.E., no cooling. my old fridge had a "reset" button which I found out after the repairman charged a bundle to press. ...
Your model doesn't have a reset button, this is non-electronic. First, tap on control panel to see if cold control is stuck. (tap on beat) If it starts it could be a bad control. Does to compressor click like it wants to start? Lastly, there is a defrost timer within the control housing, with a screwdriver rotate the timer slowly to see if the timer is stuck. If the unit starts running it could be that the timer needs to be replaced. Get back to me and I can help further if needed. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 07, 2015 | Maytag Refrigerators
LG fridge LFX25991st Ice dispenser panel keeps getting stuck
Of course it's under warranty. Call back & kick up a storm. Every singe item on that fridge is under total warranty.
Nov 20, 2013 | Refrigerators
Fridge does not get cold . Freezer is cold.
Basically there is a damper (door) between the freezer and the fridge sections which allows cold air to migrate from the freezer to the fridge, it's probably stuck or closed. without knowing the model and make, I won't be able to direct you further, but there should be a slide or dial that controls this. if you find that and it doesn't do anything, the mechanism could be damaged.
Sep 26, 2009 | Kenmore Refrigerators
Fridge model#MBR2255kes. The freezer works fine,
Your refrigerator has a control board located inside the fresh food compartment. It is hidden behind the temperature control panel. This board could be your problem. Your fridge also has air dampers that are controlled electrically. We will still need to check the defrost element behind the freezer wall. Most times when this happens the problem is related to a control board or defrost timer. If you want to check these things yourself unplug the refrigerator and look inside the control panel to see if your board has burn on back and front. If you don't find burns on board then we will open the back panel in freezer to see if the coils are frozen over. You are free to ask my help if you like I will be here. You also can go to site link below and enter the model or part number in search feature. Let me know what you find, Thanks, Sea Breeze
Click link here V__V__V
http://servicepartstec.blogspot.com/
Enter model first then it will take you to pictures of your model. On left side of screen choose photo # 3. When you click on photo 3 the part is # 5 in the photo. The part I think is the problem is part #
12868513
Let me know what you find, Thanks Sea Breeze
May 17, 2009 | Refrigerators
Fridge not working.
not sure if that model has it but if it does have a control board it will be on the back of the you will see a panel with several screws in it the relay on it is stuck need to change the control board But if it dont have a control board on it then change your relay on your compressor if you need anything else let me know and please rate me
Jan 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
