SOURCE: Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Posted on Feb 26, 2008
SOURCE: Heating elements
I just called the company @ 1-800-947-3744 and they are sending me a new toaster over to replace Model #328. DO NOT use the oven was what I was told and when the new oven arrives they'll tell me what to do with the damaged one. Mine had 2 warped areas on the front upper heating element.
Posted on Nov 25, 2008
SOURCE: Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 02, 2009
SOURCE: I have a new GE Covection Toaster Oven model
YES this is normal it is how it regulates temp by cycleing the elements ......................Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 03, 2009
SOURCE: Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Posted on Apr 02, 2009
May 08, 2014 | Black & Decker CTO4400B Toaster Oven with...
Jul 03, 2012 | Toaster Ovens
Feb 02, 2018 | Breville BOV650XL 1800 Watts Toaster Oven...
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
Jan 03, 2008 | DeLonghi AS690 Airstream Stainless Steel...
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
531 people viewed this question
