Question about Wolf Range Ovens
I have an old Wolf range with pilots Cannot get oven pilot to light Any tips? Is there a way to turn oven on without the pilot?
Model CH-6-29 BASO safety valve
Posted by jeff white on
5 Related Answers
Anonymous
  • 60 Answers
SOURCE: OVEN NOT WORKING
is this a gas stove if so and the bake burner doesnt light then you need a new ignitor and remember just because it glows doesnt mean its ok it has to draw 3 amps to open the gas valve let me know how you make out please
Posted on Sep 15, 2007
Anonymous
  • 288 Answers
SOURCE: lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Posted on Nov 04, 2007
bigg t
anthony james
  • 640 Answers
SOURCE: vulcan oven will not stay lit
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
Posted on Nov 17, 2007
ginko
Ginko
  • 19396 Answers
SOURCE: The pilot light for the oven went out.
Replace the bulb, you can buy replacements here
Posted on Jul 28, 2008
Anonymous
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
I put the oven pilot light on and soon i turn the knob it turn off
Not understanding the exact problem here. First off, is this oven old enough to have a standing pilot or is it a glo igniter type? If it's a standing pilot, then you don't put it on, it should be lit all the time. If it's a glo igniter, it will glo, heat up and then turn on the gas when you turn the knob to bake and set the temp. you want to achieve. So, I need a little more info to accurately diagnose the problem. I would like to know the age of the range, and the make and model of the range.
Mar 05, 2014 | Ovens
Royal commercial oven pilot
replace the thermocouple first. it can be purchased at you local hardware store.
if that does not fix it, you will need to replace the Baso, pilot safety. that can be purchased at partstown.com
Jul 07, 2013 | Ovens
How do adjust the pilot on a wolf commerical oven
screw is next to the pilot tube where it attaches to the safety valve. unscrew to find the actual adjustment
Jul 26, 2012 | Wolf Range F0027WS36 Gas Oven
THE OVEN BURNER WILL NOT LIGHT. THE IGNITION SYS IS WORKING. I CAN HEAR AND SEE A SPARK, BUT THE PILOT WILL NOT LIGHT.
If you can hear and see the spark lighting that acually means there is no gas entering. please check that you have have the pilot knob in possition and and and the pilot pibe and orifice is not blocked with dirt.
Jul 29, 2010 | Wolf Range F0027WS36 Gas Oven
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
Lighting a pilot light in a 30 year old roper gas range
Oct 31, 2007 | Ovens
Ovens Logo
143 people viewed this question
Top Wolf Range Ovens Experts
Harjeet s. bola
Harjeet s. bola
ray gallant
jenifer ronan
jenifer ronan
Level 1 Expert
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
