Question about Sony Televison & Video
I have recently purchased a used Sony RDR-HX900 but when I insert a purchased DVD film, the message is first :loading, then: unable to play disc. It is the correct region code.
I have tried inserting a lens cleaner disc, but the machine still says: unable to play disc
Posted by Brian Hollier on
How do I fix the power block in a Sony RDR-HX900
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 12, 2014 | Sony RDR-HX900 DVD Recorder
SONY RDR-HX 900 C13 ERROR
According to the operation manual, C 13 error indicates a problem with the HDD or the inserted DVD is dirty and/or defective. If cleaning/using a different disc does not solve the issue, then the unit will need to be submitted to an authorised SONY service centre for repair.
This could be expensive if the recorder is no longer under any warranty, and, if a built in hard drive is involved, replacement and reconfiguration may be necessary for this model. Get a quote, so that you will have an idea of the likely cost(s).
This service/error 'code' is part of the unit's self diagnosis function.
May 18, 2011 | Sony RDR-HX900 DVD Recorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Failed Sony RDR-HX900 hard drive. Replacing with new HD?
You need to get an RDR-HX900 service manual either from sony or from a supplier advertising on the internet. Service manuals typically have step-by-step instructions on replacing individual components
Mar 01, 2010 | Sony RDR-HX900 DVD Recorder
Sony RDR-HX900 160 DVD RECORDER MANUAL
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=RDRHX900&LOC=3
Hope this solves your problem. Thanks.
Sep 19, 2009 | Sony Televison & Video
Sony dvd recorder rdr gx7 sending disc error message
The laser readerwriter is most likely burned out, it is the most common failure. The option of repair is not really feasible as the cost of new is really low.
May 25, 2017 | Sony RDR-GX7 DVD Recorder
Dvd recorder won't play or record to disc
In some types of players it is very difficult to access the lens.
What you can do is buy a CD or DVD cleaning kit. This will be a specialy made disk that you insert in to the drive. Then you follow the instruction about how to use it.
Go to any store that sells audio equipment for information about these types of products.
Jerry G.
Jun 28, 2008 | Sony RDR-HX900 DVD Recorder
Disc error message
Computer Burned discs are a grey area for some players[different firmware/chipsets] There is a list on the web of players and what they will play a Google/Yahoo will reveal. Also checkout the manual that came with the player.
Jul 01, 2007 | Sony RDR-GX300 DVD Recorder
Televison & Video Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
