Question about Electronics - Others
PG156R diode equalent - Electronics - Others
Posted by Shakeel ahamed on
Franco Dosil
    Top Expert:
  • 10,535 Answers
Hello Shakeel, the PG156R diode, you can replace it with any fast diode of 1000 Volts, 3 Amper
I send you a link for you to unload the PG156R datasheet and another about the replacement
I hope you can solve the problem
Greetings Franco Dosil
Hola Shakeel, el diodo PG156R, lo puedes reemplazar por cualquier diodo rapido de 1000 Volts, 3 Amper
te envio un link para que descargues el datasheet de PG156R y otro sobre el reemplazo
Espero puedas solucionar el problema
Saludos Franco Dosil
https://pdf1.alldatasheet.com/datasheet-pdf/view/406020/PANJIT/PG156R.html https://www.yoreparo.com/tv/televisores/tubo/preguntas/1412382/puedo-reemplazar-diodo-pg156r-por-un-rg10 https://www.yoreparo.com/tv/televisores/tubo/preguntas/1284512/reemplazo-de-diodo-uf156 PG156R NTE Equivalent NTE571 1000V 3A soft recover
Posted on May 28, 2019
I know vhf pretty well. But cbs uhhhh. I have a cobra 29ltd classic. My. Buddy blew diode. Wired backwards. I replaced diode. Now it's making a constant humm from speaker. The swr meter stopped.
did you replace it with one that is equal to the one that burnt .The one you replaced should have been the reverse polarity diode which should have been right near the smaller transformer .If this is the radio it looks like you should replace some of those electriclytic caps also.Did you replace the diode with the arrow pointing in the direction the arrow is pointing ?
Apr 28, 2016 | Cobra Radio Communications
What caused my board to short out, and stop working. Lights just blink, and both fans on the back stop working...
the reason it is doing this is there is a fault on the output board, and it is going into protect mode. check the usual suspects, output transistors, driver diodes, and bias resistors. if none of the easy to replace components are shot, replace the circuit board, as this board is surface mount, there is very little hope of repairing it cheaper then replacing the whole thing. sorry
Mar 07, 2015 | Behringer Pmp6000 Powered Mixer 1600w 1600...
Ic burned
which ic burnt? if in the output (amplifier) stage it is probably a transistor (or pair) that went out. you will also need to replace the biasing resistor and diode. if in the input/preamp stage any general purpose 8 pin op-amp will work. Be careful when soldering this unit, it has a multi level circuit board. If this unit is out of warranty (over 2 years old) It will probably be more economical to purchase another unit imo. good luck.
Mar 22, 2014 | Behringer Pmp6000 Powered Mixer 1600w 1600...
Not heating
There are usually three reasons for this, the magnetron is bad "common problem" or the high voltage capacitor and diode developed a flaw. Depending on the nature of the repair, the cost for parts and labor may equal the price of a new microwave oven.
Mar 06, 2011 | Emerson Black Microwave Oven
Which kind of diode is ph c20?
It is a 20V; 500mv zener diode. Equalent is BZX-C20. OK.
Feb 21, 2011 | Televison & Video
Electronics - Others Logo
394 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
