Question about Home
I have a Regulator Waltham wall clock. When I wound the chimes, it just kept going until it wound down. How do I set it so it chimes on the hour.
UsedClockPartsdotCom
  • 277 Answers
Hate to say it, but it is time to get it to a clock repair shop. You could learn to do it yourself but that would take years and then you have the costs of the tools you would need, take it to a shop.
Main Page
Posted on Nov 26, 2016
I have a Waltham Regulator Wall clock. It chimes 4 minutes late on the hour and 1/2 hour. How do I adjust it to chime on the hour and 1/2 hour? I've tried moving the minute hand with no luck.
Try this,remove batteries,set clock to 6 o'clock,reinstall batteries,then clock should chime,turn adjuster till you are at the right time,make sure your on am or pm,it doesn't chime at 10 pm- 5 am,so that will tell you if your at am or pm.When adjusting it will chime everytime you go past the hour.You can never go backwards,if you do then you will need to remove batteries and start over,use your phone's time to set.
Mar 15, 2018 | Chime Home
Is there a way to turn the chime off?
It depends on what type of movement you have, not all clocks have the silent option. If it does it will have a silent or chime lever on the front of the dial or it will have a small hole marked silent or chime (on the dial again). If it has the hole you will need a small key to turn it.
UsedClockParts.com
Aug 28, 2016 | Home
I have a Bulova chime mantle clock, three wind, that needs sync. it is off by 15 minutes (it chimes 1/2 hour on 15 minute time etc. can you help me?
Simplest way is to remove the minute hand on dial and reseat it at the correct setting I.e one quarter turn .recheck the hour chime is on hour etc.replace glass front.
Jun 20, 2015 | Bulova Collins Majestic Triple Chime...
How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
Jan 16, 2011 | Watches
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
May 18, 2010 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Apr 05, 2010 | Seiko Mantel Clock
Our wall clock was not wound a couple of months ago (it is a chime clock that chimes on the hour and half hour with weights) and when we rewound it, everything works fine except that the chime is out of...
You were not very specific about you clock description, Many of the German clocks were using auto correct features.
You may not have this function.
Move the hour hand to the correct hour.
Hope this tip help you.
R/
David
http://antiqueclock.clockstop.com/
Mar 13, 2010 | Watches
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Home Logo
273 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
