Question about Xerox ColorQube 9201P
Xerox ColorQube 9201 does not start. Stops on the green screen that says "Please wait ... we are turning the system" + flashing green light sleep. It does not respond to anything. So as not to initialize support of chief part of the same test. Nothing happens. Please advice
5 Related Answers
skotkolr
Scott Hill
  • 558 Answers
SOURCE: Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
Posted on Jun 19, 2008
Anonymous
SOURCE: System error
7,0XX.6x Errors - Program Faults
a.
Reset NVRAM and retest.
Posted on Jul 18, 2008
goodgold
Sergey Artuganov
  • 389 Answers
SOURCE: xerox 6115 mfp has please wait on screen and has
General Troubleshooting
Product Will Not Turn On
Cannot Print the Configuration Page
Probable Causes Solutions
The power cord is not correctly plugged into the
outlet.
Turn off the product, confirm that the power
cord is correctly plugged into the outlet, and
then turn on the product.
Something is wrong with the outlet connected to the
product.
Plug another electrical appliance into the
outlet and see whether it operates properly.
The power switch is not correctly turned on (I
position).
Turn the power switch off (O position), then
turn it back to the on (I position).
The product is connected to an outlet with a voltage
or frequency that does not match the product
specifications.
Use a power source with the specifications
listed in Electrical Safety on page 1-2.
The tray is empty. Check that at least Tray 1 is loaded with
media, in place, and secure.
The product’s covers aren’t closed securely. Make sure the covers are closed securely.
Close all covers gently to avoid jarring the
product.
There is a paper jam. Clear the paper jam.
Driver Problems
With Pages/Sheet on Multiple Copies, the Output Is Incorrect
Booklet Left and Right Binding Output Is Incorrect
Did you set the correct date and time? Ensure you have set the correct Date and
Time on the control panel, through
CentreWare IS or the MCC.
The backup battery has reached the end of its
service life.
Replace the backup battery.
Media or settings are not correct. Make sure the duplex unit is installed and
enabled in the product driver.
Make sure that you are using correct media.
See Supported Paper and Media on page 6-2.
Do not duplex custom-sized media, envelopes,
labels, postcards, thick stock, or
transparencies.
Make sure that you have not mixed media
types in Tray 1.
In the product driver choose "Print on Both
Sides".
Both the driver and the application have been set to
Collate.
For Pages/Sheet on multiple copies, choose
Collate only in the driver’s Basic tab. Do not
set collation in the application.
Collate.
For Booklet Left Binding and Booklet Right
Binding, choose Collate only in the product
driver’s Basic tab.
Do not set collation in the application.
Status Messages
Message Definition Solutions
CANCELLING JOB The job is being cancelled. No action needed.
*ENERGY SAVE* The machine is in Energy Saver
mode to reduce power
consumption during periods of
inactivity.
*PLEASE WAIT!* After replacing a toner cartridge,
or after rebooting your machine
after environmental changes,
your machine automatically
pauses to do an Auto-Image
Density Control (AIDC) cycle.
This process is provided to make
reliable machine operation with
optimum output quality possible.
The machine is warming up.
Posted on Oct 17, 2009
arjoon
KENTRONICS
  • 113 Answers
SOURCE: The green power light flashes slowly and there is
is this a crt or lcd monitor, reseat the memory in the pc
Posted on Nov 16, 2009
Anonymous
SOURCE: Xerox Phaser 8200 goes through post then hangs.
We occasionally experience this also. It also flashes the indicator red/yellow/green when you try to power off. The only solution so far is to unplug the printer, let it cool down completely (next day) and then when you reboot it should cycle properly.
Posted on Apr 20, 2010
HOW TO FIX ERROR CODE 094-534
Make Sure the Paper Trays Are Configured With the Correct Paper Size, Type, and Color
To configure settings for Paper Trays 1 and 2
  1. Open the paper tray.
  2. Make sure that the required paper stock is loaded in the paper tray, and that the paper edge guides are adjusted properly to fit the size of the paper.
  3. Close the paper tray. The Printer Settings screen will be displayed on the Touch Screen.
  4. Select [Size], and then select the size of paper loaded in the tray. If this is a standard size paper, the correct size will be selected automatically if the paper guides are adjusted correctly. If necessary, select [Custom] to enter the paper size if the required size is not displayed and then enter the required X and Y values.
  5. Select [Save].
  6. Select [Type], and then select the type of paper loaded in the tray.
  7. Select [Color], and then select the color of paper loaded in the tray.
  8. Select [Confirm].
Nov 11, 2016 | Xerox ColorQube 9201P
Xerox problems
Hi Anonymous,
I suspect your question has answer by now.
If not, just visit the www.xerox.com website.
Regards.
Jul 29, 2014 | Xerox STANDARD CAPACITY MAINTENANCE KIT...
How to solve streaks in printout
If you have tried running the "eliminate light stripes" process in the troubleshoot print quality without success, you may want to look at the print quality sheet and do "jet substitution" on the ink nozzle numbers that aren't printing out. That will slightly slow down the printing, but will eliminate white streaks down your prints.
May 04, 2014 | Xerox Office Equipment & Supplies
Xerox error code 093-559
On the ColorQube 9201 and 9300, this error says "Head 3 cyan reservoir did not fill within the correct time." This a difficult machine to service so you shouldn't start without full documentation and experience.
This code may require one of a dozen parts, most of which are expensive and challenging to install.
Good luck ...Whit at www.iteminconline.com
Sep 03, 2013 | Xerox ColorQube 9201 9202 9203 Cleaning...
Xerox ColorQube 9201 error code 093-559
The ColorQube is a big $20K machine that is rather difficult to repair. Hiring a professional is the best practice. Even so, being informed will assist your discussions with the technician.
This error tells us that a Cyan reservoir isn't filling up. There are many suspects, probably Purge Line, Ink Reservoir, or Printhead. If you want to repair it on your own, you will need a service manual, and tech support.
Whit
Item, Inc.
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
Blank screen after monitor sleep just blue flashing light
First of all you can change the Power Settings in Control Panel. You can configure as you need. I mean after how much wait it should go for sleep n all.
If it takes 5 min. to wakeup that means you have so many applications running that system cannot manage or RAM is small.
The final solution just remove the Display drivers and reinstall it.
After removing please restart the system once to proceed further
Aug 03, 2009 | HP Pavilion dv9000z Notebook
Xerox ColorQube 9201P Logo
271 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
