Question about Philips Televison & Video
I have a Philips 39PFL2608/F7 that doesn't turn on.
The power supply has a high pitch whine but nothing happens when the power button is pushed. I purchased a new power supply board and it does the same thing.
Posted by Ken Ackerman on
    Top Expert:
  • Philips Master
  • 76,416 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Nov 12, 2016
I have a philips tv, model 39pfl2608 f7 and it shut down while watching. It now will not power on.
It has a power problem. Either a backlight failure or main power supply failure. Not user repairable most of the time.
Feb 02, 2018 | Philips Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
I have a Philips hdtv model # 39PFL2608/F7, it worked fine one afternoon and then when I tried to turn it on that night there was no picture, no sound, no light on the front only a high pitch whinning
Most whining sets have a problem in the power supply. A transistor under abnormal load or frequency can whine. I would turn it off, and if you are not inclined to fix such stuff, haul it to a shop. If inclined, search for a service manual, or remove the back and find the board with the power cord socket, get the numbers and search ebay and the web for a replacement board. You can also search for hints using the model number.
The whine is not good, and will eat the transistor if left in that condition. Most bad capacitors will bulge at the top when failed and you can replace with low ESR capacitors 105C rated of the same volts/farads/dimension and maybe fix the supply yourself.
Oct 27, 2014 | Televison & Video
Philips 39pfl2608
what is the cost of Philips 39" 39PFL2608/F7 screen
Jan 05, 2014 | Philips 2000 Series - 39" Class 38-5/8"...
Squealing sound on magnavox tv
if a high pitched whine or buzz it is likely coming from the power supply board.
May 15, 2012 | Philips Magnavox 42MF521D/37 Television
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
My new Acer P191W LCD Monitor has a high pitched whine that is extra loud on pages with rich and dark colors.
The PSU "power supply unit is taken on a lot of noise from the outlet. Can you tell us if you have it streight plugged into to a 120V AC outlet or is it plugged into a strip? The Solution for both is NEW strip i recommend APC or plug it into a strip and check the outlet and make sure its properly grounded this should shore up this problem or the unit itself is going out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 24, 2009 | Acer P191WBD LCD Monitor
RCA 20
sounds like the Power Transformer to me,  usually accompanied by a high pitch (almost inaudiable whine) and  sparks arcing.
This needs a professional repair..
Oct 11, 2007 | RCA F27252GY 27" TV
Televison & Video Logo
242 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
